Old 06-15-2019, 10:27 AM   #1
ArchReactor86
Drives: 2013 GBS BRZ Limited
Rev bounce 2013 Brz
I wanted to know if this was normal? It idle drops below 400 then stutters a little and bounces back up. Here’s a video:
ArchReactor86 is offline   Reply With Quote
Old 06-15-2019, 11:01 AM   #2
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Is it just me for did the RPM never drop below 500? Looks like your A/C is on which would mean this is normal.
Trueweltall is offline   Reply With Quote
Old 06-15-2019, 11:06 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If you have tuning software, bump the idle up over 800, it won't happen again
Old 06-15-2019, 12:56 PM   #4
humfrz
If you have recently disconnected the battery, the ECU may still be relearning - not to worry.
If your car has a AT, I understand that there is a patch/update the dealer can do to settle the idle down.
Like said, if your AC compressor is clicking ON, it will drag the idle down.
humfrz
Old 06-17-2019, 08:12 AM   #5
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
As mentioned, it's the A/C clutch engaging. Turn the A/C off and see if it still does it.
BigTuna is offline   Reply With Quote
Old 06-19-2019, 05:33 PM   #6
radroach
Drives: car
Also be aware if you run your front defroster it also cycles the A/C.
Mine also dips if I raise both windows at once.
Rear Passenger wheel bounce during cornering Takumidesh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-29-2019 02:34 PM
Slight front wheel bounce on sharp right turn? iceblaze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-09-2018 12:43 PM
Help! Slight vertical bounce with new wheels/tires SilverTipp Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-06-2015 11:48 AM
Cricket-Fest 2013!! Calling All FT86s! Pure's Last Meet and Dyno Day of 2013! Pure Automotive Mid-Atlantic 274 10-15-2013 10:48 AM
Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 16 10-03-2012 08:03 PM
