Old 06-14-2019, 12:22 PM   #1
Gatmando
Drives: 2017 Toyota 86
Recommendations for 2017 Toyota 86 paddle extensions
Hi. I recently purchased a 2017 Toyota 86 (AT) and my only complaint so far is the way I 'lose' the paddles when making a large turn of the wheel. I'd like to buy some paddle extenders so just looking for some recommendations.
I'm thinking adhesive based extenders would be better than the screw based ones as the screws will damage the paddles. Also, most of the extenders I've seen so far seem to be for 2013 to 2016 models. Does anyone know if these will still fit a 2017?
Thanks
Gatmando is offline   Reply With Quote
Old 06-14-2019, 12:52 PM   #2
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
These are the only ones that I am aware of for the Kouki models.
https://www.86worx.com/silk-blaze-ex....html?___SID=U
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 06-14-2019, 01:47 PM   #3
OwlDance
Drives: Halo 86, '19
I only saw some on aliexpress (questionable), but they were absurdly expensive and out of stock. The pickings are slim to none for MY17+ unfortunately.
OwlDance is offline   Reply With Quote
Old 06-14-2019, 02:38 PM   #4
Dake
Dake's Avatar
Since I don't have anything constructive to add, I'll just say, you shouldn't be changing gears with the wheel turned so far you can't hit the paddles anyway.
Full disclosure, I drive a manual. Are the paddles on the column, or do they turn with the wheel?
Dake is offline   Reply With Quote
Old 06-14-2019, 03:06 PM   #5
Gatmando
Hi @Dake. The paddles move with the wheel.
Old 06-14-2019, 05:00 PM   #6
dtrop
Drives: Wrb 2014 limited brZ
I have had these for years now. They blend with the interior well, the adhesive hasn't given me any issues.
They pretty much look like they belong as a stock item to the car.
http://www.ft86speedfactory.com/star...l#.XQQKjLxKguU
and the price is attractive compared to the other one suggested.
dtrop is offline   Reply With Quote
2017 86, extensions, paddle shifters, recomendations
MY17+ Aftermarket Paddle Extensions? OwlDance Cosmetic Modification (Interior/Exterior/Lighting) 1 02-21-2019 03:01 PM
Stark Performance Paddle Shifter Extensions Stark Performance Interior Parts (Incl. Lighting) 44 08-24-2017 02:26 PM
GCS Automatic Paddle Shifter Extensions TofuJoe Engine, Exhaust, Transmission 35 05-14-2016 12:43 AM
AT Paddle Shift Extensions look pretty sick continuecrushing Cosmetic Modification (Interior/Exterior/Lighting) 44 04-02-2015 02:08 AM
