Old 02-12-2016, 03:36 PM   #1
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
GCS Automatic Paddle Shifter Extensions
Has anyone tried the GCS paddle shifter extensions for AT cars? I was eyeballing these on eBay for a while at $60 shipped.
Now they're available in the U.S. for $34.99 + shipping. http://www.ft86speedfactory.com/gcs-...er-xt-cvt.html
Install looks super simple with an allen key setup. My only worry is that they may scratch the paddle shifters.
Anyone have these?
TofuJoe is offline   Reply With Quote
Old 02-13-2016, 02:18 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sub'd
Old 02-14-2016, 01:19 PM   #3
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
A buddy of mine in Taiwan had a few friends get these and they were pissed that the set screws damaged the factory paddles. The set screws are really small diameter and in order to apply sufficient force to retain the aluminum extensions, the pressure is more than the factory plastic can sustain without permanent deformation. In addition, since the OEM plastic isn't exactly the stiffest material in the world, the set screws will eventually rip through it.
While these look kinda cool, I'm not a big fan of touching scalding hot metal in the middle of summer. I generally keep my fingers on the paddles while I'm driving and this would be rather painful when the interior is at 150+ degrees after sitting in the sun all day.
Sithspawn is offline   Reply With Quote
Old 02-14-2016, 01:59 PM   #4
TofuJoe
Ohne Titel
TofuJoe's Avatar
@Sithspawn - thanks. I was worried the screws might ding up the paddles. Maybe I'll just shell out the $86 for the Stark extensions instead.
Old 02-14-2016, 04:24 PM   #5
xyborg
Drives: 14' firestorm
Those seem like easy pieces to 3D print. I'm willing to bet with a little bit of work you could make some that snap into place.
xyborg is offline   Reply With Quote
Old 02-14-2016, 04:47 PM   #6
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
i bought some, ill let u guys know how they feel when they arrive
mizzta21 is offline   Reply With Quote
Old 02-14-2016, 05:58 PM   #7
Tareim
Drives: 2013 Subaru BRZ
I've got some and yes they do damage the standard paddles with those allen key screws I wish I had used 3M to stick them on instead
Tareim is offline   Reply With Quote
Old 02-14-2016, 07:34 PM   #8
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
+ 1 for the Stark shifters
Kestrel is offline   Reply With Quote
Old 02-14-2016, 08:42 PM   #9
FastWhite
Drives: Subaru BRZ Limited M/T
Just to let you guys know, I had the Stark paddles on my 13 AT and when the interior gets to that ~150' mark the glue "softens" and they do come off. I ended up using Gorilla glue to keep them.
This is my experience with these paddles and no one else's.
I liked them very much.
FastWhite is offline   Reply With Quote
Old 02-15-2016, 10:24 AM   #10
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I can't get these paddles to stay on. They eventually just come off when you press on them too low. Not only do i have useless paddle extensions but also two damaged paddle shifters.
Old 02-15-2016, 01:17 PM   #11
Tareim
Being in the UK I'm not going to suffer that problem
mine came off when I first put them on, I've now reattached them but it's only screwed on using the outer screws and seem to be fine for now, if they come off again then it will be some 3M double sided tape stuff to hold them on
just thinking of ways I can over the front face to hide the damaged paddles whilst still looking ok
Old 02-15-2016, 01:41 PM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
+1 for stark I love them.
Old 02-15-2016, 02:59 PM   #13
TofuJoe
Ohne Titel
TofuJoe's Avatar
@FT-86 SpeedFactory - are you concerned about selling this product that may damage people's shifters?
Old 02-15-2016, 03:19 PM   #14
Stark Performance
Drives: 2014 FR-S
I'm sorry to hear that you experienced an issue with the adhesive. I stand behind my products and if there is a problem, I am more than happy to resolve it. I can be reached via PM or e-mail at mike@starkperformanceparts.com It seems like you were able to devise a solution so that is good, but I am here if you need me.
Thanks,
-Mike
Stark Performance is offline   Reply With Quote
Stark Performance Paddle Shifter Extensions Stark Performance Interior Parts (Incl. Lighting) 44 08-24-2017 02:26 PM
Stark Performance Paddle Shifter Extensions Stark Performance Cosmetic Modification (Interior/Exterior/Lighting) 6 02-27-2016 05:25 PM
DIY: Installing Stark Performance Shift Paddle Extensions for the A/T FRS/BRZ continuecrushing DIY (Do-It-Yourself) Guides 19 02-23-2016 10:04 PM
AT Paddle Shift Extensions look pretty sick continuecrushing Cosmetic Modification (Interior/Exterior/Lighting) 44 04-02-2015 02:08 AM
Stark Performance Paddle Shifter Extensions Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 16 12-02-2014 08:58 PM
