Old 08-02-2012, 01:23 AM   #1
BRZranger
Will this fit?
I am looking at a pair of STI 18x8.5 offset 55 wheels with Tires 245/40R18 93W. I checked the fitment thread and I didn't see offset of 55 being supported.
I am new to tires/wheels, what would it take to get these to fit?
BRZranger is offline   Reply With Quote
Old 08-02-2012, 01:30 AM   #2
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
While I am not positive on this, I would think your issue would be clearance with the front strut, as there is not much room between the wheels and the struts in the front. You might be able to get away with spacers, but I would generally not recommend going that route.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-02-2012, 09:58 AM   #3
Mild2Wild
Drives: Firestorm FR-S
Also if they are designed for the STi it will have a 5x114.3 rather than 5x100 bolt pattern.
Mild2Wild is offline   Reply With Quote
Old 08-02-2012, 10:02 AM   #4
2pt5RS
Berz
This. Unless they are BRZ STi wheels, which are available in Japan.
Only impreza STi wheel that will fit is pre 05.
2pt5RS is offline   Reply With Quote
Old 08-02-2012, 10:44 AM   #5
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
If they are BRZ wheels, I doubt the OP would be asking...
Old 08-02-2012, 10:49 AM   #6
2pt5RS
Berz
you never know...
Old 08-06-2012, 05:36 AM   #7
Mo707
Mo707's Avatar
can someone help me? I don't want to start a new thread but I need help figuring out what will fit on the FR-S. I want to buy wheels online but im not sure what will fit. No website can tell me what will fit for the FR-S because it is to new. Any suggestions ?
Mo707 is offline   Reply With Quote
Old 08-06-2012, 06:16 AM   #8
DanVIIIVI
DanVIIIVI's Avatar
Drives: 86GTS 6M
Tirerack.com will search for wheels by model. Pick 2013 Scion Fr-s and your questions will be answered.
DanVIIIVI is offline   Reply With Quote
Old 08-06-2012, 06:18 AM   #9
Panman
Panman's Avatar
Drives: 86 GTS
Tirerack has had fitments for the FR-S for months. Select 2013 scion fr-s.
Or use one of the many threads in this very section of the site.
Panman is offline   Reply With Quote
Old 08-14-2012, 10:32 AM   #10
BRZranger
What are your thoughts about using an adapter to fit 5x114 wheels? I found some pretty nice sets on Craigslist, but all 5x114! I figure if I decide to sell later, there's a bigger market for 5x114 than 5x100.
Old 08-14-2012, 11:03 AM   #11
camelflage
Drives: pinto power
the problem with this is that you will have to account for the extra 19mm (.75 inches) of offset this will add to the wheel. so a nice 18x8.5 +40 wheel suddenly becomes a +25 wheel. also hub and shank stress and what nots..
camelflage is offline   Reply With Quote
