Old 06-10-2019, 10:50 PM   #1
brzboy
Drives: 2016 brz limited
Rear end shake BRZ
In my BRZ , When starting from stopped or slow speed’s turning left or right sharply, the rear end will judder/shake a little bit until I straighten it out, or pick up a little speed only shakes for a second. Could this be the rear LSD? Is it normal? It is an automatic.
brzboy is offline   Reply With Quote
Old 06-10-2019, 11:11 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It could be a lot of things, but it's a quick check to drain the fluid from the diff ( if there is any) and fill it with some new goop. Couldn't hurt to check!
Other things -
Check yo lug nuts boi
Check you axles and make sure the boots aren't torn and leaking fluid
Are you sure it's the rear?
See if your swaybar endlinks are attached properly
Check your strut mount bolts
The Following User Says Thank You to DarkPira7e For This Useful Post:
humfrz (06-10-2019)
Old 06-10-2019, 11:15 PM   #3
brzboy
Other things -
Well it has done it for the entire lifespan even brand new
Old 06-11-2019, 08:46 AM   #4
sato
sato's Avatar
Drives: Dodge Patitas
I do remember a bit of shudder when it was new, and maybe still does it a bit accelerating out of close turns. However, I'd recommend changing diff oil as mine got a bit better when that was done. I think it's normal behavior for the LSD.
Sent from my Pixel 2 using Tapatalk
Old 06-11-2019, 08:50 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
My thoughts is it is the diff working, since you said it happened since new.
Otherwise if you are running with traction on it is very intrusive especially if you are adding throttle in a turn. The brake actuation may sound like a judder.
Doesn't sound like anything is wrong from your description.
The Following User Says Thank You to ZionsWrath For This Useful Post:
brzboy (06-11-2019)
Old 06-11-2019, 09:55 AM   #6
brzboy
Thanks everyone it was just TRACTION BEING ON STUPID ME !!!
The Following User Says Thank You to brzboy For This Useful Post:
humfrz (06-11-2019)
Old 06-11-2019, 11:19 AM   #7
humfrz
now, that's ONCE!
humfrz
brzboy (06-11-2019)
60-70 mph shake Jonbonilla Scion FR-S / Toyota 86 GT86 General Forum 8 04-06-2019 01:39 PM
TRD Griffon Second Shake Down zephyr69 Scion FR-S / Toyota 86 GT86 General Forum 1 07-08-2013 07:39 AM
Harlem Shake Simpleviet Northern California 14 02-14-2013 12:23 PM
Rev Shake injuryexpert Issues | Warranty | Recalls / TSB 0 11-21-2012 09:56 AM
First Weekend Shake down. feldy Tracking / Autocross / HPDE / Drifting 8 06-11-2012 12:24 AM
