Old 04-06-2019, 03:02 AM   #1
Jonbonilla
Drives: 2017 Toyota 86
60-70 mph shake
Recently I put on 18x9.5 rims on my 86 and I went for a test drive and drove it when I hit 60-70 mph it started to shake from the rear what could it be that causes this? And I am about 1.5-2inches low on Coilovers in the rear
Jonbonilla is offline   Reply With Quote
Old 04-06-2019, 03:17 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Welcome,
First off, right way with a 9.5 wide wheel I would assume your offsets are fucked up.
Jack the car up find where it's rubbing. Add a spacer or go back to stock, sell ill fitting wheels, work out what's the proper offset for the desired width. Wheel/tire calculator works wonders.
If not that, check lugs.
If not that, check for proper tire balancing.
If not that, check proper tire direction, if tires are one directional.
If not that, check for any lose bolts on the suspension parts.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (04-06-2019)
Old 04-06-2019, 03:21 AM   #3
Tangizdope
Drives: 2016 FRS
Wheels hubcentric? Might need hibcentric rings
Tangizdope is offline   Reply With Quote
Old 04-06-2019, 05:09 AM   #4
86MLR
86MLR's Avatar
Wheels are balanced? properly?
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 04-06-2019, 10:13 AM   #5
Jonbonilla
Everything is checked but the hub centric I’ll give that a try and I don’t rub no where I checked it out this week no rubbing at all it clears
Old 04-06-2019, 10:29 AM   #6
KDad2
KDad2's Avatar
Drives: 2013 Raven
What about your e-brake shoes? Maybe they aren't disengaging all the way. I had a similar experience.
KDad2 is offline   Reply With Quote
Old 04-06-2019, 11:53 AM   #7
StraightOuttaCanadaEh
Wes
What is the wheel out of curiosity? Were they properly mounted and balanced by a tire shop? It's usually a good idea to get an alignment done after a set of new wheels. I've driven without a hubcentric ring on one wheel and there is no shaking. The car just feels weird. Like it lunges into a certain direction a bit too quickly.
Instagram: @gt86ws
Old 04-06-2019, 01:26 PM   #8
Dake
Dake's Avatar
New or used tires? I bought a set of track tires lightly used and while the wheels were balanced one of the tires had a near imperceptible uneven-wear. No issues right up until I hit 75 or so.
Dake is offline   Reply With Quote
Old 04-06-2019, 01:39 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
did you check the alignment of jupiter with pluto? last time i had problems, it turned out it was the wonky gravitational fields.
TRD Griffon Second Shake Down zephyr69 Scion FR-S / Toyota 86 GT86 General Forum 1 07-08-2013 07:39 AM
Harlem Shake Simpleviet Northern California 14 02-14-2013 12:23 PM
Rev Shake injuryexpert Issues | Warranty | Recalls / TSB 0 11-21-2012 09:56 AM
First Weekend Shake down. feldy Tracking / Autocross / HPDE / Drifting 8 06-11-2012 12:24 AM
Ken/GReddy doing some shake downs BLikeWater FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 04-05-2012 03:26 AM
