Old 06-05-2019, 06:55 PM   #1
gt7877
Drives: turbo frs
Question OFT ROM 4000RPM LOCK
Dear
Is there any way to lock the rpm for example to 4000rpm??
Example at ecuTek:
valet mode rpm limited to 4000?
Thnx
gt7877 is offline   Reply With Quote
Old 06-05-2019, 08:14 PM   #2
steve99
Originally Posted by gt7877 View Post
Dear
Example at ecuTek:
Thnx
Yes in ecutek just use say mode 4 map and set rpm limit in node 4 to 4000 and limit throttle to say 30% as well in map 4.
gt7877 (06-05-2019)
Old 06-05-2019, 08:22 PM   #3
gt7877
Drives: turbo frs
Thnx Steve
But I mean at open flash tablet roms not at ecuTek
Old 06-06-2019, 02:17 AM   #4
steve99
Thnx Steve
Ok in oft roms you only have one map so if you set a 4000 rpm rev limiter it would be permanent.
If thats what you want just set thte rev limiters back to 4000 from the normal 7650
But other than the launch control or flat foot shift rev limiters you dont have an adjustable rev limiter using different maps like in ecutek. In oft you jist get one overall rev limiter like stock tune
gt7877 (06-06-2019)
Lock please Dylans47 Want-To-Buy Requests 2 04-21-2018 12:05 PM
Engine light and TC light at around 3-4000rpm Newfoundland_scion_frs Issues | Warranty | Recalls / TSB 3 09-02-2016 11:26 AM
CG Lock Seat Belt Lock Biggins Interior Parts (Incl. Lighting) 0 02-03-2014 09:41 AM
Removing the 4000rpm flat spot AZOOZ_95 Software Tuning 17 10-24-2013 03:56 AM
Will not rev over 4000rpm and engine light on. 000 Racing Engine, Exhaust, Transmission 14 10-03-2012 08:36 AM
