Old 06-24-2018, 07:57 AM   #1
jnmxcvi
Drives: 2016 FRS Silver
Header to Block bolt size?
Just installed Tomei UELs. We had it on a lift and torqued all the nuts fairly tight. Drove it for a week and heard one of the gaskets flapping. Got back under and noticed one of the nuts from the header to the block was missing. I knew we tightened all of them (especially that one since it was an easy one) but apparently it fell off. I was able to get a few turns on the other bolts and got rid of the noise for the most part, but if anyone knows the sizing or where to get another nut for the headers.
jnmxcvi is offline   Reply With Quote
Old 06-24-2018, 10:43 AM   #2
RichUK
Drives: Toyota GT86
They're M8 threads and 14mm nuts.
RichUK is offline   Reply With Quote
Old 06-24-2018, 07:08 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
They're 14 mm bolts with M8 threads, be sure to torque them down to 22 ft-lbs. For my install I used grimmspeed gaskets and high temp rtv silicone for extra insurance and haven't had a leak, it seems some headers have poorly decked mating surfaces and this prevents them from leaking.
Also your going to want to retorque these bolts down after a few heat cycles maybe after the first week of driving after they've going through heat cycles.
Old 07-25-2018, 09:10 PM   #4
jnmxcvi
I've been looking around for the 14mm M8 threaded nuts, but I can't find them at lowes or anywhere. There's also a 1.25 and a 1.5. If someone could just send me a link to the specific nut I need I would greatly appreciate it.
Old 07-25-2018, 11:09 PM   #5
FRSBRZGT86FAN
https://parts.subaru.com/p/Subaru__/...902370009.html
Thats for the head to engine block, simple google search for part numbers....
Old 07-26-2018, 12:04 AM   #6
sactownbwoy
sactownbwoy's Avatar
Drives: 2014 BRZ Limited
I bought these and they work perfectly:
https://www.86speed.com/products/jdl...k-nut-kit.html
I also have the Tomei UEL header
Just realized these won’t help with your situation but they will help stop what happened the first time.
sactownbwoy is offline   Reply With Quote
Old 09-23-2019, 10:57 PM   #7
sroby
Drives: 2015 Firestorm 08/05/15
I thought JDL, said they were m10. X 1.25 steel lock tabs
Not nylocks. They will melt.
sroby is offline   Reply With Quote
Old 09-23-2019, 10:58 PM   #8
sroby
I believ3 they are m10 x 1.25
010910200 Front sway bar Bolt size? Four_wheel_drifts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 06-13-2024 09:19 AM
Need Help Transmission Bolt Size J-Money Engine, Exhaust, Transmission 3 06-28-2017 01:07 AM
Exhaust bolt/nut size Shark_Bait88 Engine, Exhaust, Transmission 3 03-18-2016 03:26 PM
Looking for Bolt/thread size Mundy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-14-2015 08:48 AM
Crash bolt nut size qoncept Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-03-2013 07:38 PM
