Drives: Asphalt Gray Base FR-S 6mt
I was trying to install a camera using the Autoharnesshouse kit. Did not disconnect battery because I'm a dummy. Went to connect one the 10-pin harness to the back and saw a spark. Got everything put back together, OEM head unit turns on but no signal to speakers. The screen works, it can read from USB, etc., just no sound. I've tried disconnecting the battery for a while, no effect.
The clock and dome light still work, so it's not a fuse (at least not the radio fuse). What else should I check? Or is the head unit fried? Last edited by chi86; 06-02-2019 at 10:17 PM. |
Update: checked amp and head unit fuse just to be sure, both look fine. Upon researching this further, I learned that I had probably spliced the camera's ground into right front speaker (-) (pin 5) instead of pin 7, the ground wire. I will adjust tomorrow and update the thread.
I hope this works, because I might kill two birds with one stone: have my head unit working properly again and have a functioning rear view camera.
Either way, I have an Alpine ILX-007 standing by for install, just really hoping to get this speaker issue fixed first to be sure that the Alpine works too. Last edited by chi86; 06-03-2019 at 09:31 AM. |
Redid the camera ground wire today from pin 5 of the 10-pin harness to pin 7. Audio is back! Camera still doesn't work, but I'm done trying to get it to work at this point. I will try again when I'm installing that Alpine, maybe I'll have better luck then.
| For Sale: Stock BeSpoke Premium Audio head unit with NAV unit | Glok24 | Audio/Visual, Electronics, Infotainment, NAV | 13 | 07-22-2018 12:34 AM |
| Looking for help adding sub and amp to existing 2016 FRS sound system and head unit | Sonicp9 | Electronics | Audio | NAV | Infotainment | 2 | 02-27-2016 10:24 PM |
| BRZ Nav Head Unit | Sojhinn | Audio/Visual, Electronics, Infotainment, NAV | 16 | 11-03-2013 06:02 PM |
| head unit swap speakers sound flat and muffled | iketiak | Electronics | Audio | NAV | Infotainment | 5 | 04-20-2013 08:48 AM |
| looking for a head unit for Fr-s like the Brz. | enjoi23 | Electronics | Audio | NAV | Infotainment | 5 | 08-08-2012 02:51 PM |
