Old 06-02-2019, 04:57 PM   #1
Chuckable
Drives: 2017 Toyota 86
PSA: Koni adjustables with 245/40/17 clearance
Figured I would share my experiences with this set up in case anyone wants to run the same set up so that they will know what they are in for.
Eibach pro-kit (1”lower) with KONI “yellows”
17x8+45 wheels
245/40/17 tires with 8.2” tread width per Tire Rack (Falken Azenis)
Camber bolt in bottom position at max negative camber setting
... results in about 3mm of clearance between tire and spring perch.
This is too close for comfort for me so I’m going to install a 3mm spacer which, from what I’ve read, will still allow proper fitment on the hub as well as lug nut engagement.
Chuckable is offline   Reply With Quote
The Following 2 Users Say Thank You to Chuckable For This Useful Post:
NWFRS (06-05-2019), WC-BRZ (06-29-2019)
Old 06-15-2019, 10:29 PM   #2
BrunoS72
Drives: 2016 Scion FR-S MT Asphalt
Tire Rack SSC install instructions recommend a minimum of 3mm between the Yellows spring perch and the tire. You are probably ok with out spacers.
https://www.tirerack.com/tires/tiret...jsp?techid=339
BrunoS72 is offline   Reply With Quote
The Following User Says Thank You to BrunoS72 For This Useful Post:
strat61caster (06-15-2019)
Old 06-15-2019, 11:37 PM   #3
Chuckable
Thanks for the info. First time I came across it.
Old 06-17-2019, 10:34 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
When I was on stock struts with lowering springs and 245's it would rub slightly until the tires hit their hot pressures. I had about that much clearance, it made me really uncomfortable so I went to coil overs.
Old 06-17-2019, 07:51 PM   #5
Chuckable
That’s what I’ve done as well. Just too close for comfort for me. The Koni/Eibach setup is for sale now. It’d be great for someone who is running 42 or less offset wheels and/or smaller tires.
Old 06-17-2019, 08:55 PM   #6
ayau
Drives: Some rust bucket
What's your camber at? I'm at -1.5 with OEM crash bolt on OEM 18x7.5 215 Pilot Sport 4S with plenty of clearance.
Any particular reason for 245 wide tire? You can run 225 on a 17x8 wheel. This may give you a few more mm of clearance.
Crash bolt should be on the top hole and not the bottom per the OEM service manual.
Old 06-17-2019, 09:40 PM   #7
Chuckable
Based on my research (MotoIQ.com and other websites) 225 was slightly narrow for an 8” wide wheel depending on which tire mfr and model. Plus, I could only really find 45 series tires in 225 width and I wanted the speedometer to be correct. A 245/40/17 keeps the speedometer accurate and is within 0.3” of the ideal tire width for an 8” wide wheel. Ideally I’d have gone 235/40 for proper width but that size is pretty rare.
Old 06-28-2019, 09:28 AM   #8
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I'm coming from an E46 BMW and the stock tire size for the front was 225/40/18 on an 18x8 wheel. I went through a few brands (from PSS to cheap chinese crap) and they never even began to have a stretched look.
225's on an 8" wide wheel are not an issue.
CrowsFeast is offline   Reply With Quote
Old 06-28-2019, 09:43 AM   #9
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Agreed. 225/235 are ideal.
I got a wicked deal on PS4s in 215/45 and mounted them on a set of 8" wheels I had laying around.
They have a small amount of stretch. Though not ideal they're still within the minimum recommended size for 8".
Most of the higher end performance tires tend to fit wider than most other tires in the same size which helps.
Koni sport adjustables? Lisak6841 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-05-2014 05:28 PM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
FS: Koni Adjustables w/front housing TRev Brakes, Suspension, Chassis 1 12-10-2013 07:40 PM
KONI SHOCK VALUE SALE limited time only @ Circuit Motorsports! Lower prices all Koni Circuit Motorsports Brakes, Suspension, Chassis 115 08-30-2013 10:29 AM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 05:48 PM
