Old 05-31-2019, 08:55 AM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
recently acquired '11 Cayman vs. BRZ PP
I bought an '11 Cayman base manual a few months back. Picked it up in Phoenix and drove back to Rhode Island, visiting friends and family along the way
I got my '17 BRZ PP after cross-shopping vs. 987 Cayman a year and a half ago. My thoughts from then: BRZ felt more immediately engaging and fun to drive. Quicker steering rack, much better shifter, more supportive seats vs. standard Cayman seats, and the PP's Sachs dampers felt more "go-karty", so I got the BRZ But a year later I still wanted a Cayman...
So this year I decided to try both for a while. So far, on the street:
Cayman pros vs. BRZ:
The Cayman is quieter, less road and wind noise, better road-tripper in that regard.
Cayman feels a lot stiffer, more solid. The extra mass seems to have gone into a more rigid unibody.
Optional "sport" seats are slightly better in terms of support and comfort vs. BRZ Limited seats. But it's close... I was not going to buy one without the sport seats which are unfortunately a seldom-ordered option on these cars.
2.9 H-6 engine sounds better, has more torque and more power of course but also a broader powerband, between 222-230 rwhp from 6000rpm up to 7400rpm redline.
Cayman dampers are a lot better than the PP's. More controlled but less harsh. I think that the Sachs have too much high speed damping which gives it the initial go-kart feel, but maybe not enough low-speed rebound. Cayman suspension feels firmer but also more comfortable over bumps.
Cayman has tire pressure readout, >>> a low-pressure warning light.
Cayman negatives vs. BRZ:
Feels heavier. I would trade some noise isolation and even some solidity for 250 lb. less weight.
Shifter is CRAP. This is one thing I thought I'd get used to, but instead it just gets more annoying. An '05 Mazda3 with over 200k miles shifts *WAY* better, nevermind the BRZ! I think I shoulda gone PDK, but I was worried about reliability and potential for $$$$ repairs. Ironically the manual transmission is having to be replaced! More on that later....
Interior switchgear ergos are not as good. Door window switches are not oriented well for use by humans, pivot point for these and the climate switches gives nearly zero fingertip leverage, and the tactile clicky feel is not as nice.
If you forget to hit the "Sport" button the car feels dead slow on the street, like you're driving in 4" of molasses. Even with the "sport" button engaged, it has less tip-in acceleration vs. the BRZ. Ideal initial throttle response would be halfway between Cayman in "sport" and the BRZ, which has a little too much tip-in. Having a "sport" button for this is pretty dumb. It's a sports car, you shouldn't have to mash a button to get decent throttle response.
Porsche steering rack is slower, but steering is heavier, and you get more kickback from bumps. I don't think it gives much (if any) better feel than the BRZ's EPS. Also the Porsche steering wheel is bigger, too big IMO.
Neutral (so far):
I haven't played with the data acquisition, but it has Sport Chrono Package Plus. I should look into that... Meanwhile the BRZ's stopwatch/lap timer is super easy to use, whereas the teeny bit I've played with the Cayman's stopwatch feature, it's not as intuitive, and gave lap time readouts to the second, not even tenths? Obviously I will need to get me some learnin' on that but really a simple stopwatch/lap-timer feature should be, simple...
I'll see how it goes at the track next month!
BIG Cayman negative:
I had to buy it a new transmission
Well, Porsche factory remanufactured, anyway.
Not long after I began my trip, the car started occasionally lurching or jumping out of 2nd gear after a 3-2 downshift, maybe 20% of the time. It *only* exhibited this behavior after that downshift, never any problem with 2nd after upshifting from 1st, nor with any other gears. I thought it was driver error, due to my unfamiliarity with the vague, long-throw, cable-actuated shifter. When I didn't get any better at it, I did some research and decided the cables might be about to let go, or need adjustment. Had a shop give it a quick check-out in Atlanta and they pronounced it OK for the rest of my trip, didn't suggest any massive problems. When I got it home I had a couple of Porsche shops look at it, fully expecting to have to update the cables (Porsche had revised the bad routing design), but alas, it was worse than that... Both shops gave the "needs new transmission" diagnosis, 1st one after a brief drive around the block, 2nd one after full inspection of cables and draining trans fluid, finding metal bits. Dayumm...
Old 05-31-2019, 09:20 AM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Nice! Hope to enjoy both of them and without any other issues
Old 05-31-2019, 12:32 PM   #3
Coaster
Coaster's Avatar
Drives: Civic
Nice.
Prior to purchase did take it to shop for an inspection or just look at it yourself?
Coaster is offline   Reply With Quote
Old 05-31-2019, 01:00 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Coaster View Post
Nice.
Yes, I had a thorough PPI done at a Porsche shop in Phoenix before buying the car. They appraised transmission operation as "smooth, solid". Honestly if they didn't drive it more than 10 miles the problem might not have made itself evident. It only happened occasionally, and only after 3-2 downshift. If they weren't downshifting through the gears, they never would have experienced it.
Old 05-31-2019, 01:08 PM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
So, here is a tough question. In which conditions you'll say let's drive today the Cayman and in which conditions you'll say let's drive today the BRZ?
Old 05-31-2019, 01:13 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
That is the plan! I'll take the BRZ to the track this weekend while the Cayman is getting fixed, but next month is Mont Tremblant, I'll be taking the Cayman to that I hope...
Old 05-31-2019, 01:14 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Commute will be in the BRZ. Weekends and track days, Cayman.
Old 05-31-2019, 01:45 PM   #8
A good mix.
Old 05-31-2019, 01:57 PM   #9
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Nevertheless, in new markets like China they thing that Porsche is a SUV maker. Especially the Macan model is a big hit.
Old 05-31-2019, 02:15 PM   #10
Not just the new markets.
I see maybe two or three of the sports cars (of one model or the other) a month in the summer. Can't walk through a parking lot any time of year without tripping over three or four Macans. I probably see at least two a day just on my commute. They are freakin' everywhere here. Usually driven by middle-aged women.
Old 05-31-2019, 02:18 PM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Heh. The Porsche is in the shop. Classic.
Old 05-31-2019, 03:18 PM   #12
Sasquachulator
Pavement Grey
Pick
One
Repair
Shop
Costs
Heavy
Extras
Old 05-31-2019, 07:29 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
I know, right
In my defense, the transmissions in these cars are regarded as very durable. Endurance race teams use them as-is out of the box. I would think the P.O. must have given it latent damage from hard 1-2 upshifts or something, but the rev counts on the motor are almost unbelievably low, the car has hardly ever been to redline!
FFFFUUUUU...
Old 05-31-2019, 08:26 PM   #14
EAGLE5
Dismember
EAGLE5's Avatar
This is one reason that I never bought a Porsche and have moved away from BMWs. You never can tell, and when something goes wrong, it costs way, way, way too much to fix. 600 bucks for a used twin tranny on ebay. 2011 Cayman? Oh dear God...
ACQUIRED - STI Axle Back exhaust ZZT86 Australia Classifieds 41 06-29-2016 07:48 PM
Anyone check their VON with SOA recently? sieeegel BRZ First-Gen (2012+) — General Topics 1027 02-04-2016 01:41 PM
My newly acquired FR-S and the car it's replacing Bulldozer27 Scion FR-S / Toyota 86 GT86 General Forum 14 02-05-2015 04:17 PM
Picked this up recently fitcious Scion FR-S / Toyota 86 GT86 General Forum 5 10-05-2013 12:11 AM
Acquired a few cars today, crx si / S2000 WheelFast Other Vehicles & General Automotive Discussions 7 03-19-2012 02:19 AM
