Old 05-28-2019, 10:37 AM   #1
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Alternative to exhaust "donut" gasket?
Does anyone have any alternative weld job idea or aftermarket coupler that can have a more secure connection?
I wonder why didn't Subaru just go the typical two-bolt flange with a flat gasket like other sections have. (header->overpipe and overpipe->frontpipe)
This design does not play too well with my frontpipe/catback combination and I've been struggling with coming up with a good and cheap solution, other than use the stock catback.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 05-28-2019, 11:47 AM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Why not?
Because this setup allows flex in the exhaust system, so it reduces the chances of failure at the flanges or exhaust cracking.
You want a donut gasket at a point in the system where it would have the most amount of movement. A solid exhaust system front to back would simply force the weakest part of the system to crack under repeated thermal cycles. The added benefit is also less NVH transmitted into the cabin from the exhaust.
Go look at a car from the 1980s into 1990s, their exhaust systems are designed pretty much how you want it... they also tend to fall apart every 2-3 years.
Old 05-28-2019, 08:59 PM   #3
kch
Senior Misanthrope
kch's Avatar
Some catbacks, like the Perrin, use a flat flange with a flex section. I use the perrin catback with a flat-flange JDL FP. The only issues I've had were a failure of the FP support bracket, which was caused when I went offroading during a track day.
Old 05-29-2019, 11:22 AM   #4
Lakitu
Lakitu's Avatar
Damn it. Ah well, if the hissing gets too annoying I will just have to throw the stock catback back on, and prepare to find a better fitting one. I like the Perrin idea, thanks for that.
Old 05-29-2019, 12:47 PM   #5
Lakitu
Lakitu's Avatar
What are the effects a random 2.36" pipe in a 2.5" exhaust system?
The new overpipe I have just discovered is not 2.5", it is 2.36". Is there any big concern with performance or even just a practical matter and principle? Sound difference? Car seems perkier on the throttle, but I'm 99% sure that's just a placebo effect that always happens after I install anything new on my car. (*changes wheels* "WOW, butt dyno is reading +20whp!")
I'd like to hope there isn't too big of a difference in just 0.14", but I have been wrong before.
header: 2.5"
overpipe: 2.36" <-
frontpipe: 2.5"
catback: 2.5"
Minor OCD tendencies tells me I should probably get that replaced to a 2.5" piping, but I literally just bought it.
Old 05-29-2019, 04:53 PM   #6
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
Throw a walker 31355 gasket on the front pipe before the donut gasket. My exhaust has always been a couple mm off. This sealed it right up.
Weigaldo is offline   Reply With Quote
Old 05-29-2019, 07:24 PM   #7
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
header: 2.5"
overpipe: 2.36" <-
frontpipe: 2.5"
catback: 2.5"
You'll be fine, I wouldn't worry about this unless you're FI trying to hit over 400hp.
Trueweltall is offline   Reply With Quote
Old 05-30-2019, 08:10 AM   #8
msaikhan
Drives: frs
my exhaust was leaking around the donut gasket. The old gasket material gets stuck on surface of catback, super small but still caused leak. Take it off, make sure the surface is clean of old gasket material, put the donut back in and tighten it but not over torque it.
msaikhan is offline   Reply With Quote
Old 05-30-2019, 08:43 AM   #9
BRZ Guy
Drives: 2018 BRZ
The Greddy EVO catback installs to the front pipe doing away with the OEM donut gasket for a supplied Greddy flat gasket.
BRZ Guy is offline   Reply With Quote
SOLD: Nameless 2.5" axleback exhaust with 5" mufflers, 4" double wall slash cut tips septiq Engine, Exhaust, Bolt-Ons 0 11-28-2015 07:04 PM
Need help with Donut Gasket xcooperx Southern California 3 08-16-2015 12:50 PM
REQ: Looking for sound clip of Nameless 2.5" "No Muffler" Dual Exhaust Axleback jbsali Engine, Exhaust, Transmission 1 01-28-2014 07:22 AM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
Any alternative for the "opposed pistons" on the front fenders? NOHOME Cosmetic Modification (Interior/Exterior/Lighting) 6 10-01-2012 02:58 PM
