Old 05-24-2019, 01:55 PM   #1
ltown
Drives: 2013
innovate 210 question
i like all the info here and have been thru as much as i can but haven't been able to find exactly what im looking for. im currently looking at a used spintex 210 system. the owner says before he took it off for a different setup he had "a vacume leak whitch was found by his mechanic with a smoke test" he also said the "bypass valve" is what they think was causing a leak and others have changed the o-ring to solve the issue. he said it was still making boost just not as much in the low end. does this seem common or have any of you experienced what hes talking about? i cant look at the unit myself cause we are states apart. i also haven't received pictures of this bypass valve yet but supposed to be sending soon.
ltown is offline   Reply With Quote
Old 05-24-2019, 04:38 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yeah... I would not even think about buying used.
Save up buy it brand new. Don't buy someone else's old headache.
Old 05-24-2019, 06:17 PM   #3
kch
Senior Misanthrope
kch's Avatar
I would skip the sprintex/innovate system altogether. They're generally less efficient than other positive-displacement blowers like the 1320 TVS used by Edelbrock and Harrop, and have temperature issues.
Old 05-24-2019, 09:51 PM   #4
ltown
Drives: 2013
i totally agree, however what if you had decent mechanical knowledge and was willing to put in time/research in order to get the part working? at what price is that worth? like 1,300$ for the kit? but if it involved splitting open the supercharger and pulling out the twin scrolls count me out lol
Old 05-24-2019, 09:57 PM   #5
ltown
Drives: 2013
well say i do get it working properly, what temperature problems do you mean? like intake temps.? and by less efficient do you mean like gas mileage and drag on the motor? or like power output? i figured this kit wasn't to popular among the enthusiasts here but i dont race or track the car. its just my fun daily driver. do these problems you mentioned still occur in these types of driving situations?
Old 05-25-2019, 01:32 AM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
High intake temps, fast heat soak (esp without the intercooler), so-so reliability, very hard on the engine with all the low-end torque, low power limits.
But lots of torque from low and plenty of consistency in that torque.
Other options are better but more expensive.
Buying used is buying a headache.
Old 05-25-2019, 04:09 AM   #7
ltown
Drives: 2013
wouldn't all positive displacement chargers have that same torque strain on the engine tho? do you feel that stress is still relevant with a low boost kit like the spintex 210? ugh i mean i want to go forced induction but it seems its all just unreliable strain on these engines....... alot of kits claim its like OE but is it really? :/
Old 05-25-2019, 10:44 AM   #8
EAGLE5
Dismember
EAGLE5's Avatar
I think the sprintex is the wrong choice nowadays. There are just better kits out there. Jackson or Edelbrock CARB kits are probably the way to go. Preferably brand new. The JRSC definitely makes the power up higher, and I think the Edelbrock does a bit too. Only Innovate advantage is cheapness.
Old 05-25-2019, 03:12 PM   #9
bfrank1972
Drives: 2013 FR-S Argento
Humm, not so sure if it's the "wrong choice". Plenty of people have had issues with just about any kit, and plenty of happy campers with this kit. It produces plenty of power, just fine for anyone, and on E85 it can approach 300whp with a nice torque curve. Plus it sounds cool. I do think the TVS units are better units but the innovate kits are solid with 250whp and a nice torque curve on pump gas.
Sent from my SM-G965U using Tapatalk
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
86TOYO2k17 (05-25-2019)
Old 05-25-2019, 05:47 PM   #10
86TOYO2k17
Drives: 2017 toyota 86
Intercooled and If you have access to E85 or WMI heat soak isn’t really an issue. And if your goal is 290-300whp or less. It has the most power in entire powerband/area under the curve at that power. Intercooled E85 70mm pulley Full bolt ons on a friendly dyno will have a 250ft lbs torque plateau from 3500-6500rpm with 300whp peak. A centrifugal sc with a 300whp peak will have a linear curve from 200-250ft lbs at 3500-6500rpm in comparison. Obviously the centrifugal sc has a much higher ceiling close to 400whp if you wanted more though.
Also sprintex was one of the first kits on the market so many people bought it and it’s had a long time in use so much more time and opportunity for failures compared to other kits. And really a small percentage had those failures.
Old 05-25-2019, 06:40 PM   #11
ltown
Drives: 2013
the one i was looking at was not inter cooled, i also noticed that there are no more non intercooled kits out anymore. they have been discontinued. the intercooled ones are around the 4,200 to 4,600$ range. about the same as a Jackson racing model. i guess im leaning twords a new kit now so i dont have to deal with the problems of the used kit i was originally looking at.
Old 05-25-2019, 06:44 PM   #12
ltown
Drives: 2013
the jackson kit was one im considering as well, if i go new that is. installation seems tedious but something i can do at the shop im sure. theres alot of parts added to the car and a ton more failure points so its something that would have to be monitored closely as most the kits are anyways.
oh and by the way, whats the difference in the "c30" and "c38"?
Old 05-25-2019, 09:45 PM   #13
86TOYO2k17
Are you planning on building the engine?
What are your whp goals?
What kind of power delivery do you want?
Low/mid torque or high end peak hp?
Car use? DD, spirited driving, canyon/backroad, autox, track, dragstrip, stop light/roll racing?
C38 is larger with more potential, but even the C30 is plenty capable of blowing stock engine. I believe it’s about 350whp vs 400whp max potential on a normal non hero dyno.
Old 05-26-2019, 05:16 PM   #14
EAGLE5
Dismember
EAGLE5's Avatar
Bigger blower = more potential for more money. If you're going to stay on the carb tune with stock pulley, get the c30. Don't waste your money. If you're going to build your engine, swap pulleys, and get a custom tune, get the C38.
A lot of people find the JRSC reliable.
The innovate is just old tech. Why bother?
None of this is going to be as reliable or easy to keep up as stock. Maybe you should just go buy a Z or something else with more power stock? An Ace header, billet power blocks, and tune gets the car into a pretty sweet NA spot.
Question about FI / Innovate azynneo Forced Induction 47 06-15-2015 08:09 PM
Question; What Strut-tower bars and cross-braces fit with Innovate Stage 2 I/C SC? Michael Blue Forced Induction 5 05-26-2014 01:30 AM
Question: vortech+innovate possible? cjsporl1996 Forced Induction 32 03-28-2014 07:47 PM
Innovate Motorsports Supercharger Question jjkerr626 Forced Induction 3 01-04-2014 08:12 PM
Innovate OT-2 jamesm Engine, Exhaust, Bolt-Ons 0 12-03-2013 10:38 AM
