Old 05-21-2019, 02:50 PM   #1
MilitoGFC
MilitoGFC's Avatar
Drives: Scion FRS
Air Fuel Ration Sensonr
I've been getting a code for lean condition. I had the sensors tested and the air fuel ratio sensor is reading out of range.
1. Can someone show me where is it located on a stock FRS?
2. I'm running HKS Equal length headers. Is this the sensor on the picture attached???
MilitoGFC is offline   Reply With Quote
Old 05-21-2019, 03:05 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
That is one of the two oxygen sensors, yes.
Old 05-21-2019, 03:17 PM   #3
MilitoGFC
MilitoGFC's Avatar
Drives: Scion FRS
Does the car have Two O2 sensors and an air fuel ratio sensor or just Two O2 sensors?
Old 05-21-2019, 03:17 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
And it's located in about the same place on a stock FRS. The first one is right before the cat.
Old 05-21-2019, 06:37 PM   #5
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
One of the few times I'm glad I live in OR where road salt is not used.
PetrolioBenzina is offline   Reply With Quote
Old 05-21-2019, 06:59 PM   #6
DarkPira7e
DarkPira7e's Avatar
They are synonymous. An oyxgen sensor measures your air/fuel ratio.
Old 05-21-2019, 07:07 PM   #7
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
That crack doesn't look good. If it's leaking exhaust, that'll cause your AFR to be off.
BirdTRD is offline   Reply With Quote
The Following 7 Users Say Thank You to BirdTRD For This Useful Post:
DarkPira7e (05-21-2019), Grady (05-21-2019), humfrz (05-21-2019), Qadthane (05-25-2019), RToyo86 (05-21-2019), Spuds (05-21-2019), Tcoat (05-23-2019)
Old 05-21-2019, 07:14 PM   #8
Grady
Grady's Avatar
Good eye!
Old 05-23-2019, 11:43 AM   #9
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
An "oxygen sensor" and "Air/fuel Ratio" do perform the same needed function but are different. In Toyotas, typically the primary Sensor (Before cat) is an A/F ratio type sensor, and the Secondary (Post cat) is the traditional Oxygen sensor type. They both determine air fuel ratio, the main difference is how the voltage is read by the ECU.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following User Says Thank You to NARFALICIOUS For This Useful Post:
DarkPira7e (05-23-2019)
Old 05-23-2019, 12:48 PM   #10
extrashaky
Drives: 2014 BRZ Limited
Intermittent fuel pressure/signal drop (Fuel regulator prob?) Decimus Issues | Warranty | Recalls / TSB 6 03-27-2019 08:38 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 10:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 07:43 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 07:21 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
