poor man's evora
Drives: Turbod BRZ
gravity feed auxiliary fuel tank
I was trying to get info on if anybody has attempted a trunk mounted gravity feed fuel tank. i get around 220 miles on a full tank of e85, limited stations around me. I was wanting to add a 10 gallon tank in the trunk. I have only seen this with guys on trucks mounting the tanks in their bed.
The Dictater
Drives: '13 Red Scion FRS
Not that I actually recommend doing this, but they do make fuel cells that fit in place of the spare wheel/tire. That's probably your best bet since putting something in the trunk would likely prevent you from getting to the spare anyway.
Geo Tyrebighter Esq
Drives: '13 scion fr-s
It's a pressurized system.
With a vent outside for the gravity to work, you'll likely get a CEL into limp mode. Depending how high, it may drain into the EPA carbon evaporation canister and ruin that too. A couple race fuel jugs in the back would be simpler, but you need to get out to unstrap them and top off.
"I gotta rock." -- Charley Brown |
| DIY : Draining the gas tank - Methods to empty fuel tank | Mermoz | DIY (Do-It-Yourself) Guides | 13 | 10-09-2025 02:56 PM |
| Larger Fuel Tank | go_a_way1 | Engine, Exhaust, Transmission | 33 | 11-18-2016 07:53 PM |
| Draining the fuel tank | Fricke | Engine, Exhaust, Transmission | 13 | 06-20-2016 11:52 PM |
| FS: OEM Fuel tank with pumps | MicheleAbbate | Exterior Parts (Aero, Lighting, Etc.) | 3 | 06-02-2016 03:08 PM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 03:39 PM |
