Old 05-17-2019, 03:14 PM   #1
msaikhan
Drives: frs
Cam sensor leaking oil?
2013 frs, replaced short block
I saw some oil dripping from the bottom of engine on passenger side, while replacing headers. Oil got on the grounding wire on the bottom of the engine.
I'm pretty sure it's coming from the cam sensor, top passenger side. Got O rings from subaru and planning on changing the o ring.
Anyone else had this problem?
I'm not taking it the car back to the dealer, usually comes back with another problem.
msaikhan is offline   Reply With Quote
Old 05-18-2019, 08:00 AM   #2
Vital
Drives: 2015 BRZ
Yes its a common issue on earlier models. http://www.ft86club.com/forums/attac...1&d=1413834741
Vital is offline   Reply With Quote
Old 05-18-2019, 10:31 AM   #3
msaikhan
Drives: frs
i seen this before but none of these are about the cam sensor oil leak.
Old 11-01-2021, 06:48 PM   #4
CockpitCruiser
Custom Title
CockpitCruiser's Avatar
Drives: GT86
I have a very slow leak, if we should even call it that. Early Harleys used an automatic lubrication system that drew oil from the oil pump to lubricate the primary chain. The oil would drop off from the primary chain into the primary chaincase, which had a drain hole that allowed oil to drop to the floor. They didn't leak tho, so I don't think my car is leaking either. It just has a hole somewhere that allows oil to drop to the pan under the engine
Eat, Sleep, Drive, Work, Drive, Ride, Eat, Sleep. Repeat
CockpitCruiser is offline   Reply With Quote
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help Johnders2586 Issues | Warranty | Recalls / TSB 9 04-04-2023 03:32 PM
Leaking oil next to o2 sensor! Updated feldy Issues | Warranty | Recalls / TSB 5 05-11-2015 10:40 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
