Drives: 2015 BRZ
Subaru 80w-90 Diff oil
I was at the dealership recently and saw that they have 80w-90 diff oil. I was just curious does this work for our cars? I know the manual says to use a GL-3 and higher or 75w-90 oil. Heres a link for reference.
https://parts.subaru.com/p/Subaru__/...A427V1800.html |
Drives: scion frs 2015
i use 80w-90 works fine in my car got tired of buying the small quarts
Drives: 2015 BRZ
Drives: '13 BRZ
I just used this in my diff. Changed my trans fluid at the same time with 75w90.
| Which is better? Reaplcing rear diff bushings? or installing rear diff brace? | Frs30 | Engine, Exhaust, Transmission | 22 | 04-13-2020 10:23 AM |
| Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? | mistople | Engine, Exhaust, Transmission | 10 | 09-21-2018 06:01 PM |
| Diff Mount Inserts install - Diff won't lower??? | ChRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-17-2017 12:07 AM |
| OEM Diff | Kregar | Mid-Atlantic | 1 | 07-12-2016 04:30 PM |
| Swap AT Diff with MT Diff | sydious | Engine, Exhaust, Transmission | 2 | 03-17-2016 02:59 PM |
