Old 08-01-2012, 03:27 PM   #1
Dustin@Dynosty
Coming soon.... Silicone Hose Kits
We have worked with Venair USA in the past and have had great results with their silicone hose kits and have just sent off a set of OEM rubber hoses off to have them replicated in silicone. This will include the radiator and heater hose sections.
Advantages of Silicone Hoses:
  • Venair Silicone hoses can withstand far higher & lower temperatures than the standard EPDM rubber hoses commonly found in OEM engines.
  • Silicone hoses are the preferred choice for motorsports teams and enthusiasts alike because of their increased durability and performance and their amazing high gloss finish that is available in a variety of colors.
  • Silicone is ideal for water, forced air applications, induction joints, dump valves, air lines and many other uses and industrial applications. In addition, it is suitable for all coolant hoses, washer tubes, air hoses, vacuum hoses, water hoses and more.
  • Typical color choices are Black, Red, and Blue
We will post a link to the for sale thread when these become available!
Thanks
Dustin
Dynosty
502-384-8882
Dustin@Dynosty is offline   Reply With Quote
Old 08-01-2012, 04:06 PM   #2
jm1681
Drives: MKVI VW GTI
Any possibility of a hose to replace the rubber hose from the throttle body to the stock airbox?
jm1681 is offline   Reply With Quote
Old 08-04-2012, 10:28 AM   #3
Dustin@Dynosty
I am away from the shop and vehicle but unless I am missing something simple... there isn't a hose from the TB to the stock air box. There is a hose running from the crank case vent to the intake just right before the TB, is that what you are referring to? That hose, while molded from the factory would be easy to replicate in a non molded silicone hose of your color. I do not believe it changes sizes from the intake to the crank case vent but can verify on Monday.
Old 08-04-2012, 10:32 AM   #4
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
I think he's asking about the intake hose.. The large diameter plastic tube, not so much "hose"
DIE1000DEATHS is offline   Reply With Quote
Old 08-04-2012, 11:48 AM   #5
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
available in blue?
kendalldwhite is offline   Reply With Quote
Old 08-04-2012, 07:24 PM   #6
jm1681
Drives: MKVI VW GTI
This. Sorry for the terminology confusion.
Old 08-04-2012, 08:47 PM   #7
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Avo makes it but it would be nice to have competition and see what they could do
Hopefully this comes out in red!!!!!
Silverdub is offline   Reply With Quote
Old 08-04-2012, 09:08 PM   #8
kendalldwhite
if u look at Venair USA they have blue but yeah they will prolly have red
Old 08-05-2012, 06:23 AM   #9
jm1681
Drives: MKVI VW GTI
Just found a link to it, thanks
I've been trying to figure out which intake to go with and you just made my life a lot easier
Old 08-19-2012, 01:51 PM   #10
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Waiting for you to finalize your set!
BTW, could you let me know the diameter of the coolant hose coming to the radiator?
This is the place where the temp sender will live
MSTiFK8R is offline   Reply With Quote
Old 08-19-2012, 03:48 PM   #11
subatoy
subatoy's Avatar
Drives: subatoy
I there a dyno on this?
subatoy is offline   Reply With Quote
Old 08-24-2012, 04:49 PM   #12
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
Anyone know for sure what size heater hoses are on the FRS heater core? 1/2" or 5/8".
Roadstercycle is offline   Reply With Quote
Old 08-25-2012, 02:11 AM   #13
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Venair are definitely good but too expensive, I would wait until a competitor comes along with a similar product and see then how the pricing stacks up
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 08-25-2012, 02:20 AM   #14
zooki
Drives: waiting on a 2021...
Talking
I'm surprised nobody has asked how much weight these hoses are going to save...
zooki is offline   Reply With Quote
HID PnP Kits engee Cosmetic Modification (Interior/Exterior/Lighting) 25 02-05-2013 04:29 PM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 12:30 PM
aftermarket body kits jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-24-2012 02:15 PM
NA engine kits? Levi Engine, Exhaust, Transmission 36 11-17-2011 11:45 PM
