Old 05-12-2019, 11:37 AM   #1
Celica94
Drives: 1996 Toyota celica
Only one seat warmer light is turning on?
Is this normal? It appears to still be warming up on my seat (to be honest I can’t really tell if it’s just my body warmth or the seat
https://imgur.com/a/uqyk8c8
Celica94 is offline   Reply With Quote
Old 05-12-2019, 12:19 PM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Both seat heaters are fused independently. SEAT HTR LH and SEAT HTR RH.
It's OK to replace the fuse, but if it blows again you'll have to replace the heater as it's likely shorted, you wouldn't want to keep replacing fuses and using the heater or worse, use a higher amp fuse and burning a hole in the seat.
Old 05-12-2019, 01:08 PM   #3
Celica94
Oh ok. So the fact that the light isn’t coming on is meaning the fuse has blown? Is it recommended I take the car back to Toyota? I bought the car from a Toyota dealer ship pre owned about a week ago
Old 05-12-2019, 02:28 PM   #4
RZNT4R
The way the circuit is designed, you could have a light on the switch but no heat if the power circuit and switch ground were OK but the heater element circuit was open, or no light and no heat, which would be a bad power circuit (this includes the fuse).
I don't know how used car warranties go in AUS, but if it's been a week, you probably have a recourse. don't mess with it and bring it to them. Replacing a seat heater yourself isn't necessarily hard, but it's a pain in the butt.
Old 05-12-2019, 02:57 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
You have a requirement for heated seats in Australia??
Old 05-12-2019, 03:09 PM   #6
RZNT4R
Australia is pretty big, so between the north and south there should be a good difference in temperatures. And while it's bisected by the tropic of capricorn, a quick glance through a google search tells me some regions can go down to the single digits celcius during winter, so while it's not dangerously cold (like where I'm from), seat heaters, in short bursts, are comfy in that range. Here people keep their seats on full burn from november to april.
My 86 doesn't have any
Old 05-12-2019, 03:42 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
I have 2 fully functioning seat heaters... Used only once... Open to offers....
Old 05-12-2019, 03:43 PM   #8
humfrz
Maybe the OP is just old -
humfrz
JD001 (05-12-2019)
Old 05-12-2019, 04:23 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
The butt heater switches are notorious for burning out. They short closed when they get hot and let go.
Old 05-13-2019, 09:40 AM   #10
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Could just be the little light inside the switch; this is what happened to mine.
The light inside the driver's-side switch no longer turns on, but the seat heater itself still works perfectly. I was told by my dealer that you cannot replace the light by itself; you have to replace the whole switch, and a switch was $50 plus tax, so I elected (for now) to just live without the light since the heat itself is still working.
@bpennerz
SLVRSRFR is offline   Reply With Quote
The Following User Says Thank You to SLVRSRFR For This Useful Post:
Ultramaroon (05-13-2019)
Old 05-13-2019, 11:27 PM   #11
ftpwny
Drives: 2013 Subaru BRZ
I have this same issue. Heater still works, but the light is out.
Sent from my Pixel 3 XL using Tapatalk
ftpwny is offline   Reply With Quote
The Following User Says Thank You to ftpwny For This Useful Post:
SLVRSRFR (05-14-2019)
Old 05-14-2019, 11:23 AM   #12
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
I've had the same issue for years. Seat still works fine.
rapidcars is offline   Reply With Quote
Old 05-14-2019, 01:47 PM   #13
Ultramaroon
not playing cards
Or maybe it's just the light.
Speed wobbles and abs on light turning frstplace Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2018 07:28 AM
Turning off air bag light s0sl0w Electronics | Audio | NAV | Infotainment 2 07-16-2016 11:24 PM
Turning off maintenance required light Prowl647 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-18-2014 02:01 AM
Dome light not turning on Vincenttam Scion FR-S / Toyota 86 GT86 General Forum 2 01-12-2014 03:51 AM
Center console seat warmer trim, Limited only BRZPDX BRZ First-Gen (2012+) — General Topics 16 04-18-2013 03:55 PM
