Old 05-12-2019, 08:45 AM   #1
TaxCollector
Drives: 2016 BRZ
Help wheel noob before I buy these please
Hi there so I want the 16' look and it fits for where I live as theres a lot of rough back roads and such so a more rally style setup is what I'm going for. I tried to get enkei compes but they discontinued the bolt pattern.
So right now I'm deciding between Black Rhino rumble 16x7 +15 and Motegi MR 139 16x7.5 +40. Will these both clear brakes, and are the rhinos offset just too low? I like the rhinos a bit better but I'm not sure how they will fit. I used the wheel-it-fit thingy and theres some poke with the Rhinos which I'm fine with. Want to go 225/50/r16 for tires. Thanks for any help here.
TaxCollector is offline   Reply With Quote
Old 05-12-2019, 10:02 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
16x7.5 +40 >>> 16x7 +15
Always hated poked but narrow wheels....
Old 05-12-2019, 10:29 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
There is a bit though, that if one wants to drive same wheels all year round, and as in Canada there actually IS winter weather, then i'd prefer x7. Not so much for fitment of any way, as to also well fit with narrow winter tires, eg. of 195 width, instead of fitting wide tires in winter or stretching past reasonable narrow ones. Not sure on that offset though.
Old 05-12-2019, 02:17 PM   #4
Steve
Steve's Avatar
Drives: 6MT
Stock suspension? If so I think the +15 offset will poke too much, at least for my taste. I personally run 16x7 +35 wheels in the summer and I think they look great with negative camber in the front as they poke noticeably more than stock. I have a suggestion for you, Sparco Terra wheels come in 16x7 +35 and definitely have the look you are going for.
Steve is offline   Reply With Quote
Old 05-12-2019, 10:14 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
16x7 +15 has the same poke as 17x9 +40, a common size used.
I LIKE TIRES!
Old 05-14-2019, 07:58 AM   #6
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I'd strongly suggest looking for other wheels. Had a horrid experience with motegi, bought a set used and they bent horribly 3 weeks later over a pothole I've driven over repeatedly because it is minute.
Sparco is a good brand, and the Terra has a very good reputation. I've run the Spacro Assetto Gara for a few years and they've been great.
Old 05-14-2019, 11:11 AM   #7
Jordanwolf
Rice King
Jordanwolf's Avatar
+1 for Sparco rally wheels
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Noob needing wheel help Texas2016Frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-04-2016 06:50 PM
Wheel noob here, have a few questions! Strife Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-22-2016 10:40 AM
Wheel noob here, need help on fitment! Sufficial Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-04-2015 06:18 PM
Wheel noob needing help Th3rdSun Scion FR-S / Toyota 86 GT86 General Forum 20 07-30-2015 10:06 PM
Noob wheel questions pornflakes AUSTRALIA 11 05-31-2013 01:43 AM
