Drives: 2017 Subaru BRZ
Gauges
Anyone wanna chime in on a good boost gauge and temp gauge and mounts?
Sent from my SM-G960W using Tapatalk |
Drives: 2016 Halo FRS
Defi hands down
Rust bucket enthusiast
Look up cravenspeed steering wheel column mounts, very cool. I like Prosport's gauges. I've used Prosports, Glowshift, and Defi. For a simple temp and mechanical boost gauge, I wouldn't worry about any being much worse than the other - the sensors are generally the same, it's just the gauge look that you have to deal with.
LMGTFY
Drives: 13 FRS, 91 Miata
ProCrastinationConsultant
i liked the concept, but didn't like the concept of the obd refresh rate. i haven't tried it, just past experience with a scangauge tells me otherwise..
Drives: Q5 + BRZ + M796
I have Defi.
If you looked at my build page and you are referring to my setup then no, those mounts are a separate purchase. One is the Ortiz Custom gauge pods. The other one is a vent insert. But there is a mount or housing that comes with the gauges.
#10 |
Drives: 2016 Subaru BRZ
I use Prosport Gauges, they are local to me and the face on mine are similar to the stock cluster. I use a Block8head vent gauge pod, triple but if I could do it over I would go with the double. Triple sags and I had to put something under it on the end.
#11 |
not playing cards
#12 |
Drives: swp mt '14 brz premium
Speedhut. Made in Utah. Have them made your way.
#13 |
not playing cards
I see my next purchase. Do you have one for oil?
#14 |
Drives: 2014 DGM BRZ
| Gauges | aslanteye | Electronics | Audio | NAV | Infotainment | 16 | 10-05-2015 03:43 PM |
| Gauges for frs? | wootwoot | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 02-26-2015 01:19 PM |
| Necessary gauges | misooscar | Engine, Exhaust, Transmission | 5 | 09-18-2014 02:42 AM |
| Gauges | Lunatic | DIY (Do-It-Yourself) Guides | 14 | 07-04-2014 02:59 PM |
| Gauges | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 07-24-2010 06:26 PM |
