Drives: 2018 BRZ TS
rear camber issue?
Hey all, I just lowered my car with some TEIN flex's. I have never lowered a car before so I need to know if I just need to get an alignment or if I actually need to do anything about the rear camber. I have no rubbing issues and the car drives perfectly well. Rear tires are 255/30-19's.
Before: ![]() ![]() After.... ![]()
2018 BRZ tS #282 of 500 DELICIOUS TUNING Edelbrock FI, E-85 Flexfuel, DeatschWerks pump and injectors, SpeedFactory ceramic UEL, Invidia R400 cat-back, ACT HD street clutch and flywheel, TEIN Flex Z coilovers, Stance wheels, Michelin Pilot Sport 4
Benz Tech
Drives: 2017 BRZ Premium
Yes, you need an alignment ASAP.
[insert cool phrase here]
Drives: BRZ Premium
Rule of tumb, when ever you mess with suspension that directly affects alignment specs, you need to have it checked.
Chances are you are still within spec but might as well check and adjust if need be.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Benz Tech
This is my alignment after installing Eibach Pro springs, 1" drop. Front tires would have been wrecked in a short period of time. Rear camber was also way off, especially cross camber.
Specs are in degrees and minutes. -0*12' is -0.20* Last edited by maslin; 05-10-2019 at 05:24 PM. |
Drives: 2013 FR-S Series 10
Alignment shop won't be able to adjust camber unless you've added adjustable LCAs, but at least you'll be able to zero (or near-zero) your toe. which will be out of whack
Looks about right for a street car.
Drives: Subaru BRZ
And need a BBK... the current set up look tiny...
| Camber issue | Twitchy313 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 03-16-2019 05:47 PM |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
| Does toe affect camber in the rear? More camber on one side after alignment | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 11-30-2014 09:37 AM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
