Old 04-21-2019, 03:35 AM   #1
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Should I consider battery corrosion protection on the brand new car?
Hi guys,
Is it a good idea to use battery terminal protectors (ie NOCO https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER) and corrosion spray (ie NOCO https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER for a brand new car and battery?
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 04-21-2019, 03:50 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Those felt rings are more than enough in all honesty.
Even if you do get a bit of corrosion on the terminals a little bit of water, baking soda, and a brush can clean that up in no time.
Then again.... a bit of battery corrosion is the lest of your problems.
Also FYI $9 for those rings? Lol don't be a chump. Those are $3 max at any auto parts store.
Old 04-21-2019, 04:42 AM   #3
JIM THEO
Drives: BRZ 2018
Marine waterproof grease may be?
JIM THEO is offline   Reply With Quote
Old 04-21-2019, 09:50 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I worked for AAA and got tingly when I saw the signature red spray on terminals. It meant I wasn't about to replace their hardware and could do my job effectively.
Please just spray them if you will never check your battery. I'm in Vermont and had plenty of MA cars that were corroded with the connection hardware itself rusting apart.
Old 04-21-2019, 10:07 AM   #5
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
why would you spend 30$ on stuff when 30 seconds with a wire brush fixes it? Plus the oem batter will shit the bed before that 30$ is worth it
Breadman is offline   Reply With Quote
Old 04-21-2019, 11:40 AM   #6
DarkPira7e
DarkPira7e's Avatar
The real issue is the connection hardware rusting. When it does, you can't just unbolt the connectors and put them back on. You have to cut the connection ends off and add new hardware, since you can't re-tighten the bolts to get a snug fit onto the terminal
Old 04-21-2019, 05:01 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
this is what i install on all my cars. it's an all-in-one kit that includes the felt rings, and then a small squeeze thing of dielectric grease that i coat the terminals with. it's worked well so far
https://shop.advanceautoparts.com/p/...inal+protector
way better than opening up the hood on a bad day and finding a furry friend eating my battery!
Old 04-22-2019, 06:40 PM   #8
Grady
Grady's Avatar
Or you could just keep your engine compartment and battery clean!
Old 04-26-2019, 10:59 PM   #9
Busybee
Busybee's Avatar
I know this will be a very basic question. Is there anything that I have to be careful about taking out the battery wire when I put the protective pads? I mean Is there a possibility that It can I can get an alert on my screen ? Is it just fine to release the cables put the pads, spray the the protectant and assemble back.
Thanks
Old 04-26-2019, 11:53 PM   #10
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Thanks
Yeah. Don't let the positive terminal touch metal.
Also do not attempt to do this with your bear hand. Use protective gloves (oven mitts ok) head gear with full face guards, thick rubber apron, a grounding wire and protective foot wear.
Also let your neighbors know your attempting to battery work. And for shits and giggles call the fire department just so they can be on stand by. I'm sure @humfrz would agree
Old 04-27-2019, 12:03 AM   #11
Busybee
Busybee's Avatar
Old 04-27-2019, 12:36 AM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Just get the spray and give the terminals a spray once in a while. No need to take anything apart.
Old 04-27-2019, 01:24 AM   #13
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
How dare you give him a logical simple answer.
Old 04-27-2019, 01:27 AM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Sorry, I don't know what I was thinking.
Anti-Corrosion (ACF-50 vs Corrosion Block) nico_rsx Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 12-02-2017 02:57 PM
Master Battery Cutoff Kill Switch Safety Alternator Protection Racing Shutoff hirollaz Engine, Exhaust, Bolt-Ons 1 09-05-2017 01:47 PM
STI Battery Tie Down - Brand new wrb Interior Parts (Incl. Lighting) 4 06-03-2014 04:42 PM
BLACK PERRIN PULLEY AND LIMITED GRIMMSPEED BATTERY TIE DOWN BRAND NEW IN BOX genometuning Engine, Exhaust, Bolt-Ons 0 09-26-2013 09:49 PM
FS: Brand New Braille B2015 Battery kanundrum Mechanical Maintenance and Tools 7 01-20-2013 01:35 AM
