Old 04-15-2019, 03:56 PM   #1
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Quick Q on Injectors & Coils
There's no actual performance gains in upgrading injectors and ignition coils on a stock engine, correct? These are just only for a bump in combustion efficiency mostly beneficial to FI applications is my current understanding. Just looking to confirm.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
The Following User Says Thank You to Lakitu For This Useful Post:
Boris_Petrov (04-15-2019)
Old 04-15-2019, 06:13 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Not efficiency, it's for when you run out of injector capacity when you fill the cylinders with more air. Not seen anyone upgrade the coils except for those that have had ones fail.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Lakitu (04-15-2019)
Old 04-15-2019, 06:15 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Injector capacity = horsepower output. You upgrade based on target HP output + rest of engine build.
Ignition coils, same as above if you have/foresee ignition issues with your setup. It's a blanket statement but these are things you don't upgrade for the sake of upgrading.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
churchx (04-15-2019), Lakitu (04-15-2019)
Old 04-15-2019, 06:22 PM   #4
Lakitu
Lakitu's Avatar
Beautifully said, gentlemen. Thanks!
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
FS: NRG Quick Release 3.0, Quick Lock, Steering Wheel akiranakayama Interior Parts (Incl. Lighting) 13 08-16-2016 10:40 AM
FS: New NRG Quick Tilt & As-Is NRG Quick Release bear89103 Interior Parts (Incl. Lighting) 2 10-16-2014 01:11 AM
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 05:59 PM
Quick Release or Quick Lock Steering Wheel and Theft defense too? 1086 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-24-2014 04:50 PM
