Old 04-11-2019, 02:08 AM   #1
juniorrr
Drives: Scion Frs
Need some help picking some springs!
Hey Guys, so I’m looking for some springs that will drop me 1inch and that will improve drive feel and maybe even a little performance if possible. I don’t track the car but I do touge the mountains sometimes so I don’t need crazy performance springs but some improvement would be cool.
I don’t know anything about suspension brands and which springs are good and which aren’t so I was hoping you guys could help me out and refer me to some that are best for my buck. Thanks in Advance I really appreciate it!
juniorrr is offline   Reply With Quote
Old 04-11-2019, 02:24 AM   #2
Skyehigh55
Drives: 2017 Pure Red BRZ w/ Perf Package
Eibach Pro-Kit or RCE Yellow's springs are in the ballpark of a 1" drop although the Eibach's are more like 7/8" but also keep the rear biased OEM feel.
A similar thread with more feedback on the two listed:
https://www.ft86club.com/forums/showthread.php?t=25820
The two have had plenty of positive reviews on this forum so you can't really go wrong with either. Just don't go lower than 1" is my suggestion. If the wheel gap is still too much for your taste with even a 1" drop, just get bigger wheels
Happy shopping fellow FT86 driver!
Skyehigh55 is offline   Reply With Quote
The Following User Says Thank You to Skyehigh55 For This Useful Post:
Will BRZ (04-23-2019)
Old 04-11-2019, 10:14 AM   #3
juniorrr
Drives: Scion Frs
Aren’t those springs more for the tracks though cuz they feel much harder than stock? I want something a little bit softer than stock springs and does do a little bit for performance. Also how come going lower than 1inch is bad? I was gunna get bigger tires but I wanted to keep the speedometer and odometer pretty accurate so I stayed with similar height.
Old 04-11-2019, 10:35 AM   #4
Vital
Drives: 2015 BRZ
No, those are fine for street and mild tracking. TRD springs, Eibach Pro-Kit, RCE Yellows, Hotchkis springs all lower about an 1" which is not too low and fine for DD. Any lower spring you get is going to have higher spring rates than stock. You can look into the RSR Downs they only lower the car half an inch or so 15mm. I have RCE Yellows and they are great i felt they ride better than stock and are just as comfortable as stock they are amazing springs and i would highly recommend them. Going lower than 1" means you need higher spring rate. lose shock trave, and maybe bottoming it out, and blowing it out your shocks quicker its just not worth it. Here are some RSR Downs for sale. http://www.ft86club.com/forums/showthread.php?t=133828
Vital is offline   Reply With Quote
Old 04-11-2019, 12:23 PM   #5
Gunman
Drives: 2019 Mazda Miata RF
I went with Hotchkis, and they suit me for daily driving, and weekend mountain drives. The spring rates are a little softer than most of the aftermarket springs, but stiffer than OEM. Combined with their ARB's, the chassis can be tuned to fit you.
Gunman is offline   Reply With Quote
Old 04-11-2019, 02:17 PM   #6
juniorrr
Drives: Scion Frs
So there aren’t many springs that actually act softer than OEM then I take most are either the same or stiffer.. Are there any that a little softer then OEM without sacrificing performance?
Old 04-11-2019, 02:53 PM   #7
Vital
Drives: 2015 BRZ
Yes, that is correct. You cannot have a soft suspension and the performance. When talking performance the suspension does need to be a little stiffer. I really dont think any of these springs will give you too much of a harsh ride these are all great options for staying within 1" lower. Yes, you will feel the road more and the imperfections and bumps, but its really not that bad. The only other spring i can suggest is the new USDM STI springs, but STI never releases their spring rates for some reason.
https://subaruonlineparts.com/subaru...gs-p-4682.html
Old 04-11-2019, 08:10 PM   #8
Skyehigh55
The USDM STI pink springs also don't lower the car exactly 1" so those might not be what you're looking for. Just a heads up.
Old 04-11-2019, 10:14 PM   #9
Decep
Drives: 2013 FR-S Series 10
If you don't want firmer than stock then definitely don't buy lowering springs. Losing suspension travel can be a bit painful at times depending on road conditions around you.
You might consider spending the bones on coilovers. Do it right and do it once. I tried a couple lowering spring options and was never quite happy with them.
The Tein Flex A are smoother than stock. Plus if you factor in the cost of new dampers since the stockers will wear faster with stiffer springs, it's not THAT much more $$.
RCE superstreets are nice (im biased) on the softer settings, i highly recommend them.
The Following 2 Users Say Thank You to Decep For This Useful Post:
Racecomp Engineering (04-11-2019), wparsons (04-15-2019)
Old 04-11-2019, 11:20 PM   #10
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
You will not find something that will be cheap, lower your car, be more comfortable than stock, and improve performance.
Even with coilovers you should be prepared to spend a little more $ for better dampers.
Lots of spring options that will provide you with a tolerable ride when you are looking at 1” drop and lots of entry level coilovers that are tolerable as well. But be prepared to compromise and level set your expectations.
Popular spring options: RCE, eibach, TRD
Popular coilovers: tein flex a, bilstein, rce, kw
Don’t rush into picking something up because it’s cheap— having gone through multiple spring and damper setups, and trying various different coilover setups, I think it would be worth it to save just a little bit more and, like @Decep said, do it right and do it once.
For what it’s worth, I’m happy with my Swedish coilovers
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 04-12-2019, 01:15 AM   #11
juniorrr
Drives: Scion Frs
I see so from all the information that you guys are giving me, coils seem to be the best way to go because I change it from very soft ride for daily and then stiffening then when I actually want more performance. Plus they are safer Than springs I’m assuming. So I was thinking of going with the Tein flex z’s I was curious what’s your opinion about these? And also do you guys have any you recommend for around the same price and flex z’s? P.S. Appreciate the info!
Old 04-12-2019, 12:01 PM   #12
Gunman
Safer, in what regard? a quality lowering spring should have no safety issues.
Technically, the car has coilovers on it OEM, the coil is over the damper
The Following User Says Thank You to Gunman For This Useful Post:
wparsons (04-12-2019)
Old 04-12-2019, 03:51 PM   #13
CatDaddysBBQ
Drives: '13 FR-S
If you're sticking with stock shocks, RCE yellows are fantastic. .8" drop, better handling, less body roll and no less comfortable than stock.
If you want the next step up, pair a set of RCE Tarmac springs (slightly more aggressive than the yellows) with a set of Bilstein b6. performance benefits are even bigger, and the ride is FAR better than stock. Same .8" drop.
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
juniorrr (04-14-2019)
Old 04-15-2019, 02:23 PM   #14
juniorrr
Drives: Scion Frs
Quick question then guys, if I had to pick between RCE Yellow Springs or Tein Basis Coilovers. Which one of these two would give me better performance? I’m between these two right now. Thank you!
Picking up a 86, or maybe not... andyzpandy Scion FR-S / Toyota 86 GT86 General Forum 24 05-12-2015 04:04 AM
A little help picking a set up.... wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 11-18-2014 06:41 PM
Need help picking Springs? This tool will help. kayoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-10-2014 12:03 PM
Picking her up at 5! remorse87 Scion FR-S / Toyota 86 GT86 General Forum 14 10-07-2012 10:51 AM
Need Help Picking New Phone Calais Off-Topic Lounge [WARNING: NO POLITICS] 10 02-22-2011 04:29 PM
