Drives: WRB BRZ MT
Eibach Pro-Kit vs RCE Yellow
Looking for a subtle drop on my car. What's the differences between these two?
You're gonna get a lot of flak for this, springs are a commonly discussed topic and can quickly be searched for lots of info.
To prevent this from turning into another "OMG forum etiquette" thread, what are you looking to achieve besides a mild drop? Looks only? Track days? The specs of each spring set are really easy to find, so what kind of comparison are you looking for? |
#3 | |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
Having stock shocks vs, say, Koni Yellows. Will be a difference.
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
Drives: it has 4 wheels and a motor
The RCE springs work great on the stock shocks/struts as would the Eibachs. Difference through is that the prokit is designed to lower the car without really increasing performance. The RCE springs will lower the car and increase performance dramatically.
Tony |
Drives: DGM
Tony,
Would you say "increase in performance" at the sake of comfort? Is there a compromise on handling vs road comfort on poor road conditions between the two brands? Thanks for your input. |
#7 | |
Drives: E46 M3 (daily) / EG Civic (track)
The RCE springs are more of a square set up with similar front and rear rates. The Eibach springs have a rear biased spring rate like the OE BRZ and FR-S springs do. The difference comes down to driver preference. Ironically, the RCE springs are made by Eibach as mentioned in their post below. You can't go wrong with either. http://www.ft86club.com/forums/showt...?t=9936&page=2 |
#8 | |
When In Doubt...
Drives: Slowww
@Phaedrus29 can chime in hopefully!
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
Drives: 2013 WRB 6MT BRZ Ltd.
For your BRZ, the RCE Yellows are 66% firmer in front and 28.5% firmer in the rear, and the drop is roughly 3/4 of an inch all around.
The Eibach are about a full inch all around, and as Jackson stated, keeps a rear bias (33% firmer in front, 40% firmer in rear). Personally, I liked that the Eibachs matched the stock setup's spring rate ratio more, and offered a tiny bit more drop. From what I remember reading about spring rates in RWD cars, firmer rear rates increase your ability to slide the tail, which is something I wanted after putting wider, stickier tires on my new wheels that I installed at the same time. While I'm sure there's not a significant difference between the 2, my guess is that the RCEs would make oversteering a tad more difficult, which is probably better for speed on a track, but less fun when you want to get sideways. |
#10 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
For me and a couple other guys in my area the Eibach Pro-kit dropped the car 7/8", not a full inch. Pretty close though.
I think the pro-kit is similar to stock handling wise as far as rear end kick out except it feels a hair bit better in a corner.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#11 | |
That symmetry is something I notice with the wheels as well. While I wanted to go with the same wheels at each corner, I can't help but wonder if I should have gone +35s only in the rear, and dropping to +45s for the fronts.. |
#12 |
I guess it really depends on what you want. If you are looking for outright grip and lap times on a road course I think the RCE would be a bit better. Lowering too much on a strut based car is never a good thing especially when strut travel is limited and non adjustable.
Tony |
#13 | |
#14 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| Help removing yellow spots | MattR | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 56 | 06-04-2016 01:17 AM |
| White n' Yellow. | Asterisked Accolade | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 33 | 08-02-2015 04:01 AM |
| Does this mean a Yellow BRZ/GT-86 will be in Initial D Stage 6? | LeeMaster | BRZ Photos, Videos, Wallpapers, Gallery Forum | 43 | 06-23-2015 01:53 PM |
| Yellow fog tint looks awesome! | DookDookDGM | BRZ Photos, Videos, Wallpapers, Gallery Forum | 37 | 11-07-2012 03:40 AM |
