Old 04-10-2019, 01:14 PM   #1
WNDSRFR
Drives: FR-S,GTI
PO171 code and traction light
1950 miles after the recall was done I got a PO171 code and the traction control light came on. Ever since the recall the car has had a weird idle dip to where the engine almost stalls. I got the big idle dip and the CEL and traction light came on. Drove home ,the car ran fine. I read the code with a OFT and cleared it. I started the car and it ran kinda rough. I figured I would log fuel mixtures today. Went to start the car this morning and it will not run. I plan on towing it to the dealer on Friday.
I was wondering if anyone knows what might be going on so I can talk intelligently to the service guy.
The Following User Says Thank You to WNDSRFR For This Useful Post:
humfrz (04-10-2019)
Old 04-10-2019, 02:01 PM   #2
humfrz
Well, THAT sucks -
I'd just let them know what code it threw and let them figure it out. Then they may tell you that you should have left the code so they could diagnose it better.
Oh, I'd start by looking for a vacuum leak -
humfrz
WNDSRFR (04-11-2019)
Old 04-10-2019, 06:37 PM   #3
steve99
Yes as above
Vaccuum leak like hose on bottom of intake manifold or exhaust leak letting 02sensor see fresh air will do that. Since it now wont stsrt more likely intake leak. Could also be a bunch of other things like maf or 02 sensor bad
Also check the DI computer has all three bolts tight it box on side of motor, bots are how it get earth\ground .
https://www.autocodes.com/p0171_subaru.html
The Following 2 Users Say Thank You to steve99 For This Useful Post:
humfrz (04-10-2019), WNDSRFR (04-11-2019)
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 10:00 PM
ABS and Traction light- No Code neroman98 Issues | Warranty | Recalls / TSB 12 07-21-2018 07:06 PM
Abs and traction light no tailights replaced brake light switch now what? Brzlimited661 Scion FR-S / Toyota 86 GT86 General Forum 5 01-28-2018 07:04 PM
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 10:28 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 08:37 AM
