Old 04-08-2019, 02:19 AM   #1
dave-
Drives: 86 GT
Stock PCV outlet - faulty/leaking?
Car has been boosted for a few years and heavily tracked. From turbo install, I had a mishimoto compact can connected between the crankcase breather (edit, thanks tomm.brz) outlet below the AC compressor and then returning to my intake between the air filter and turbo inlet.
Have noticed a lot of oil on top of the engine block, around this crankcase piece below the AC compressor and only on that side of the engine. I cleaned it up before last track day and the photos shown are from a days running basically so the PCV bit seems most likely point of leak to me?
Nothing relating to the PCV valve or crankcase breather has been changed to my knowledge. Given boost, am I supposed to have changed something there? Could it leaking due to boost?
dave- is offline   Reply With Quote
Old 04-08-2019, 02:38 AM   #2
tomm.brz
Drives: brz 2017 hksv2
that s not the PCV, it s the crankcase side breather
Personally I would try putting a check valve in line of the real pcv, near battery, or directly swap it with wrx pcv (it costs few bucks) and see if it makes better the crankside
Old 04-11-2019, 04:19 PM   #3
toast
Drives: 14 BSP Edelbrock BRZ
Seems silly to ask this but are you sure the hose on the breather isn't cracked or weeping?
toast is offline   Reply With Quote
Old 04-11-2019, 08:14 PM   #4
dave-
Drives: 86 GT
I'm not and that's a fair question. Going to degrease and clean it all this weekend. Will check the hoses also.
Old 04-11-2019, 08:21 PM   #5
toast
I'd check the hose first just so you don't get water or degreaser in any openings. I can't think of any other source for oil from that side of the motor.
Old 04-15-2019, 12:41 AM   #6
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Where did you get the wrx pcv? I have been wanting to change mine! I am guessing the dealership?
scion fr-s is offline   Reply With Quote
Old 04-15-2019, 01:51 AM   #7
tomm.brz
ypu can ask dealership or just get it online, it s cheap
code: 11810aa141
