Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: 2017 Subaru BRZ Limited
got a P0300 code today
Noticed CEL today, car was driving fine. Plugged my ecutek dongle and used the software to get the code, it was a engine misfire P0300. Googled it and the descriptions were all over the place, from replacing spark plugs to take apart the entire engine. I just used the Clear DTC function of the ecutek ProEcu and now the CEL is gone.
I’m running ACE header with Delicious flex fuel kit and tune. Hopefully this is a one time thing. Any reason I should be concerned? The car only has about 5000 miles. I did just put in a new tank do E85 couple days ago, maybe bad gas? ![]() Sent from my iPhone using Tapatalk |
Benz Tech
Drives: 2017 BRZ Premium
P0300 is random misfire, no way to diagnose that over the internet. Not much to check since it’s cleared either.
Move on and see what happens, bad gas could certainly do it. |
#3 | |
If the code doesn't return, I wouldn't worry about it. If it does return, and you plan on taking your car into a shop, DO NOT erase the code before you take it in. Why not? Because without the code in place, it will limit the shops efforts to diagnose the problem. humfrz |
Drives: UK GT86
Flexfuel kit, are the logs showing any issues with the output?
.: Stealth 86 :.
Drives: 2018 Toyota 86 GT trim (Thunder)
If it makes you feel better:
I got a P0300 on startup @ 1300 miles (almost a year ago). Took it to a local dealer, they checked the gas to make sure it wasn't watered down (it had been raining heavily for weeks). All was well. After they cleared the CEL, haven't had any issues since (knock on wood). I'm now at ~10.5k miles. ![]()
[insert poor quality, phone-taken picture here]
Contact delicious tuning and ask if this is an issue with a tune when it comes in contact with bad fueling that's basically you asking if they've seen this before. Were you running e85, 93 or a mix at this point?
FI car - P0300 code, and now hesitation/bogging at higher rpm | FirestormFlex | Engine, Exhaust, Transmission | 9 | 08-13-2020 10:57 PM |
P0300 and P0304 CEL -- uh oh! | empower-auto | Issues | Warranty | Recalls / TSB | 26 | 04-16-2018 03:19 PM |
CEL P0300 & C1421 | AfterFXNinja | Issues | Warranty | Recalls / TSB | 1 | 07-05-2017 07:11 PM |
Thank you Veterans. Enjoy this coupon code for today! | FRSport.com | Announcements, Contests, Giveaways | 0 | 11-11-2015 01:52 PM |
p0300 code... Anyone else?? | NickFRS | Engine, Exhaust, Transmission | 1 | 09-05-2013 11:33 PM |
