Old 03-30-2019, 11:06 AM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Tom's Tail Lights w/ Turn Signal conversion?
So, you know how you can convert your turn signal to blink on the brake light, and that signal becomes your reverse light? Can the same be done with a Tom's Tail Light? (I'd imagine). If anyone's done this or seen this, were there any complications? And did you have to switch out the signal LED for a white LED (new reverse light)?
scottryan is offline   Reply With Quote
Old 03-30-2019, 12:43 PM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
Probably easiest to wire in a 4 wire trailer converter. Run reverse signal to the turn input on the lamps. Obviously, the reverse lights would be whatever colors the turn signals are now.
maslin is offline   Reply With Quote
2013-2016 OEM Fog lights, Tail Lights, Mirrors, Flasher+Turn Signal Bulbs; Car Cover MugsBRZ Exterior Parts (Aero, Lighting, Etc.) 4 03-21-2019 07:19 PM
Tom's Tail Lights and Front Turn Signal LED finch1750 Cosmetic Modification (Interior/Exterior/Lighting) 17 10-12-2017 11:03 AM
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 11:51 AM
tom's tail lights usdm dot approved turn signal problem ed_423 Cosmetic Modification (Interior/Exterior/Lighting) 7 02-20-2017 09:24 PM
WTB Buddy club tail lights w/amber turn signal Sharpe978 Want-To-Buy Requests 0 12-12-2014 05:36 PM
