TRD supercharger kit - GA
I'm contemplating changing directions with the car and racing, so putting a feeler out for this supercharger plus everything else you need to install/run it. It's still not 100% PnP but pretty close.
I'm asking for $5500 plus shipping for the setup. It has recently been refreshed by Jon Bond performance and powder coated wrinkle red, I haven't used it since then. The rotors were also re-coated at the same time. The internals of this are a TVS 1320 but it's quite over engineered compared to some of the other TVS based kits. This is what would also be included with the supercharger: Custom dual-pass air/water heat exchanger and all AN fittings/lines to hook it up with a small reservoir to help bleed the system. Bolts to where the AC condenser used to, there is no way to keep the AC with this setup. Bosch water pump. I can give you the mounting I used for it, but may want to build your own based on your setup. 76mm throttle body, modified to use the BRZ stock plug and ECU. New MAF tube, coupler, and filter. A/C delete bracket plus idler and belt to use with the rest of the stock pulleys. Modified stock crank pulley to be used with the supercharger drive pulley. This supercharger is driven off a separate belt than the rest of the engine. 100mm, 95mm, 90mm, 85, and 80mm pulleys and belts. For some bit more may be willing to part with the built engine it's attached to but haven't thought too much about that. Picture installed previously: On E75 the car made 347whp with the 95mm pulley.
Drives: FRS
I did not even know this was available. That is so sexy! Wish could of sold my turbocharger for this.
What info do you have on built engine. Willing to negotiate for the whole thing. Like engine parts and supercharger? Last edited by Evil Rocky; 03-27-2019 at 01:50 AM. |
The engine has forged 12.5:1 pistons (CP), Pauter rods, ACL bearings. new crank. It's bored .020 over. Was machined/asembled by Turn in Concepts. The heads are ported and built with all Ferrea valvetrain including the larger valves. Plus other things like RacerX fuel rails, 850cc Bosch injectors, etc.
Drives: 2015 BRZ Limited
Weren't these like $26,000 new and you had to buy two? Good luck with sale. These don't surface often.
Sent from my Pixel XL using Tapatalk |
Drives: '13 BRZ Ice Silver Metallic
Would you consider cash/trade a 2014 Harley iron 883 for the engine /supercharger together?
Located in north ga. Last edited by BrZ_Good; 04-07-2019 at 11:24 PM. |
Bump. Sorry not looking for a trade right now.
Bump
Make an offer, but won't really listen to anything lowball. Also willing to drive up to 4 hours or so to meet someone, since shipping would be pretty substantial.
Drives: 2014 White FRS
So not trying to hi-jack this thread but is this kit CARB legal in all 50 states? Don't really know much about it so just thought I'd ask.
Thanks. Free bump! |
#10 | |
Check out Edelbrock, Jackson Racing, Vortech, I think there's another one but Edelbrock and JR are the go-to's right now. This thing is probably destined for a show car or casual track/weekend toy and it will be real cool.
| WTB Supercharger | Tim86UK | Want-To-Buy Requests | 0 | 03-17-2017 10:07 PM |
| HKS Supercharger GT Property Kit or HKS Supercharger V2? | Ragingft86 | Forced Induction | 5 | 12-10-2016 01:59 PM |
| supercharger | frs baby | Canada Classifieds | 16 | 02-02-2016 10:46 AM |
| TRD Supercharger.... | JRCmx | Forced Induction | 4 | 03-22-2015 04:04 PM |
| supercharger? but by who? | carbonBLUE | Forced Induction | 14 | 11-02-2012 11:10 PM |
