Old 03-24-2019, 06:27 PM   #1
Scremin@ATS
Drives: 2017 86, 94 Supra TT, 93 MR2T,90GT4
Swap TRD (Limited) LED dash gauge cluster into base 2017?
I’ve found limited info on this, only one thread talks about swapping it into a 2015.
I have a 2017 base model. Does the Limited /Trs Gauge cluster plug right in?
If so, has anybody done it? We’re you able to set the mileage using tech stream or any other way? The 2015 thread indicated it could be programmed.
Any help is appreciated, I really wanted the TRD model but don’t want black paint, wish they would have opened up the options!
Scremin@ATS is offline   Reply With Quote
Old 03-25-2019, 10:54 AM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
There are multiple threads on this forum. Iwould suggest you start reading here. http://www.ft86club.com/forums/showt...=114910&page=2
The Following User Says Thank You to Summerwolf For This Useful Post:
Tokay444 (03-25-2019)
Old 03-25-2019, 11:02 AM   #3
By the time you went through the cost and hassle of changing it you may as well have just traded it in for one with the display.
Old 03-25-2019, 02:02 PM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
ehhh, seems like a pretty easy swap from what people are saying.
Only thing that's kind of dippy is the control panel being made that goes in the center console's blank space. Doesn't look very factory.
Old 03-25-2019, 02:17 PM   #5
Got to buy one first and it would need to be new and programed. That is not going to be cheap.
If you change the cluster for a used one you need to deal with the security coding between the cluster, immobilizer and ECU. It is not a simple swap and go.
Old 03-25-2019, 07:18 PM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Still way cheaper than trading it in for one with the cluster, lol. The things you're talking about have already been solved. Someone pioneered it and did it.
http://www.ft86club.com/forums/showthread.php?t=129867
Old 03-26-2019, 09:39 AM   #7
Sasquachulator
Pavement Grey
yup super simple....
Just as simple as Toyota could have given the 86 more power!
Just that simple!
Nothing is ever that simple......
The Following User Says Thank You to Sasquachulator For This Useful Post:
Jordanwolf (03-26-2019)
Old 03-26-2019, 10:07 AM   #8
Summerwolf
Panda Trueno
Summerwolf's Avatar
Just that simple!
I wouldn't personally do the cluster swap, but I have seen it done, there are multiple threads on it, and it seems relatively easy. People are out here figuring out canbus systems, figuring out e85 compatibility and full auto tuning. Let alone figuring out stock gauge and dash systems with engine swaps.
Why would a cluster swap with the same plug and a proven way to do it not be in the realm of cheap when the other option is trade the car in, lol.
DIY - Gauge Cluster LED swap Blackrsx DIY (Do-It-Yourself) Guides 216 11-04-2021 10:40 AM
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 07:32 PM
Used gauge cluster swap hachi roku [86] Electronics | Audio | NAV | Infotainment 0 09-23-2018 06:26 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 03:55 AM
