Old 03-19-2019, 04:08 PM   #1
Erickson
Exclamation *HELP* Swapped battery now most electronics don't work?
I just recently swapped out my battery for my 2013 BRZ. Pretty basic stuff took the old one out and popped the new one in. Now when i start it my windows don't respond, I have no power steering, radio doesn't work, wipers, traction control, basically a whole lot has stopped working. Lots of lights on the dash also. I'm guessing it's a fuse somewhere but don't know enough to check myself. Really don't want to bring it into a dealership and wait 2 months for it to get fixed. Any one have any idea what's going on?
Erickson is offline   Reply With Quote
Old 03-19-2019, 07:37 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well, young grasshopper you have the classic case of "oh shit the battery leads touched metal and fried stuff" or "oh shit, I put it in backwardss."
Your in luck, most of the time it's just the main fuse that's in the positive terminal, or a few fuses in the fuse box or the secondary fuse box inside the cabin.
FYI, not all repairs require dealership. Any local mechanic shop can do the same exact fix. Call up any local shop tell them your story. They will help prices are usually cheaper.
Old 03-19-2019, 08:05 PM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Yep, chances are you popped one of these fuses. The fuse block assembly is about $15, check it with a multi-meter first.
BirdTRD is offline   Reply With Quote
Old 03-20-2019, 10:04 AM   #4
Erickson
Thank you very much! Bringing it into my local shop as I type
Old 03-31-2019, 07:37 PM   #5
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
As mentioned above, it could be one or more blown fuses.
This happened to me on my previous Toyota, 2011 Rav4 to be specific. I just removed the cables from the battery, let it sit for several minutes and then reconnected the battery cables. Everything worked normally since.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
2013, battery, brz, ecu
Electronics are freaking out.. HillCountryGuru Issues | Warranty | Recalls / TSB 5 05-15-2014 01:50 AM
LS swap electronics mhiscott Engine, Exhaust, Transmission 8 12-20-2013 07:52 PM
FRS Electronics shutting off for split second? sega_102 Scion FR-S / Toyota 86 GT86 General Forum 9 05-15-2013 11:32 AM
Nifty electronics mods proficience AUSTRALIA 41 05-13-2013 02:09 AM
