Old 03-17-2019, 04:59 PM   #1
FoxTrot86
FoxTrot86's Avatar
Drives: Stock FT86
New OFT Freezing Up on Make/Model
I’ve tried multiple times following the instructions on the back of the OFT v2 box, as well as videos online. Whenever I select the make/model the OFT completely freezes. OFT is updated through the latest update on Open Flash Manager. (2017 Toyota 86 M/T) Attempted to: Reset ECU via Battery disconnect and pulling fuse. Multiple attempts of following the online videos/box instructions. (Doors closed, all lights off, radio off.) No damage to either car female port or OFT cable and pins. Tried using other makes (FRS/BRZ) with the same result of beeping and freezing as the Toyota 86 option. No reply to my ticket after a few days, and was hoping someone here would have further guidance, or experienced something similar and had resolved it.
FoxTrot86 is offline   Reply With Quote
Old 03-17-2019, 05:40 PM   #2
steve99
It possible oft has hardware fault.
Only thing I can think of is update the template file, if its V2 make sure you use V2 template as the V1 is for the old tablet different screen.
https://support.openflashtablet.com/...rs/42000057969
Tcoat (03-18-2019)
Old 03-17-2019, 07:10 PM   #3
FoxTrot86
FoxTrot86's Avatar
Drives: Stock FT86
Updating the template to v2 worked! Thank you so much, this headache is finally over.
The Following User Says Thank You to FoxTrot86 For This Useful Post:
steve99 (03-18-2019)
Freezing Windows? MuseChaser Issues | Warranty | Recalls / TSB 12 01-11-2016 01:10 PM
Window Freezing TSB... 5AD86D Issues | Warranty | Recalls / TSB 77 03-19-2014 08:18 PM
Make: Toyota, Model: Scion FR S jsvegas Scion FR-S / Toyota 86 GT86 General Forum 22 11-28-2013 09:27 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
