Old 03-08-2019, 12:18 AM   #1
504
504's Avatar
Drives: 2014 86 GTS
Ecutek missing tables
Hi all,
I'm just compiling a series of tables for edit with my tuner through ecutek but can't seem to find any form of hotstart enrichment tables in proecu at all?
Basically car stalls after cranking on anything with 60+C IAT and have monitored a super lean start, pretty confident hotstart enrichment will cure me but tables don't appear to exist :/
Overrun enrichment doesnt exist also?
Also I'm looking at zeroing all tables in di ratio uptown and including 0.6 load, any one forecast issues with relation to this?
Thanks in advance!!
504 is offline   Reply With Quote
Old 03-08-2019, 01:17 AM   #2
tomm.brz
Drives: brz 2017 hksv2
one way would be, took a "virgin" stock rom for that car (not from ecutek database) and star modifying what you dont have in ecutek, with romraider
then save, and reapply all other things in ecutek
slow and painful, otherwise you could ask a master tuner to take a look, they usually have access to more tables
anyway compare very well tunes on ecutek and romraider, hotstart could be some of the "cranking fuel" tables in ecutek there are a lot of them
Old 03-08-2019, 02:10 AM   #3
steve99
Originally Posted by 504 View Post
Hi all,
Thanks in advance!!
It is more likely to be a port injectpr scaling or lantency issue.
Elso lots of ecutek users would have problem
Note some injector scalings are for 40 psi and car euns about 60 psi fufel pressure so that needs to be taken into account
Note car stsrts on port only then runs on port only for a minute or two regardless of whats in the pi\di tables
The maf correction after start tables provide some emrichment their in neutral and in gear tables.
Old 03-08-2019, 04:26 AM   #4
504
504's Avatar
Drives: 2014 86 GTS
thanks so much fellas for the comments
tOMM.brz
"star modifying what you dont have in ecutek, with romraider
then save, and reapply all other things in ecutek"
yeah man I've been doing this and have a series of tables already sitting, waiting for pasting. cheers bud
Steve99, you make a good point that many ecutek users would have the issue. I may be attacking it incorrectly. Unfortunately I cant really alter injector scaling as itll impact fuelling for everything else, nor do I have the expertise to dictate values in that field as it doesn't seem my tuner does : /
does thew car still look at maf after start tables even post 80c coolant? cause it doesnt go through the warm up process like at 70c or under. maybe I can increase the values in 80c+ as a last resort part fix?
the DI ratio was more for cruise drivability, im really favouring DI more but worry 0.6load is too high for DI only on e85 3000rpm ish
Old 03-08-2019, 08:48 AM   #5
steve99
tOMM.brz
Ecu appears to ise those maf after start tables for first minute or so after all starts
Higher coolant temps have less maf offset in standard tables
Old 03-08-2019, 11:40 PM   #6
steve99
Also have a look at
Closed loop fueling conpensation - coolant temp 1 and 2 maps under warm up enrichment in ecutek
OFT - Tables Missing Cells Lorastus Software Tuning 3 05-07-2017 05:45 AM
Pool Tables? Nevermore Off-Topic Lounge [WARNING: NO POLITICS] 37 03-01-2016 01:03 PM
Help on OFT Missing tables j.boy Software Tuning 24 02-02-2016 04:44 PM
Coffee Tables? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 11 10-20-2014 03:51 PM
Can DBW tables be changed via Ecutek tune??? Norkoastal Engine, Exhaust, Transmission 1 09-11-2012 06:51 PM
