Old 01-21-2016, 04:15 PM   #1
j.boy
Drives: GT86
Help on OFT Missing tables
Need help about missing tables on OFT A01J roms including engine load limits A, B, and C; all tables on Per injector pulse width; Requested torque base (RPM) and others were mostly DTC tables on the A01J rom compared to G roms. What to do to have some of these tables?
j.boy is offline   Reply With Quote
Old 01-21-2016, 04:31 PM   #2
steve99
You would need to talk to @Td-d he does the definitions
Old 01-21-2016, 04:56 PM   #3
j.boy
Drives: GT86
thanks steve. Would PM be enough?
Old 01-21-2016, 08:03 PM   #4
steve99
You can try he is also a moderator on romraider.com its best to use the email option there
Old 01-23-2016, 03:09 AM   #5
steve99
their is only two load limit tables its just some defs label then a b others b c..
try this romraider def
https://raw.githubusercontent.com/TD...R_ZA1JA01J.xml
just be carefull if your editing an oft rom with this def as it wont have lc\ffs parameters.
i belive that A01J is latest compatabe rom so the oft rom shoul be A01J internally , but carefully look at the tables if anything looks weird dont edit
j.boy (02-01-2016)
Old 01-28-2016, 12:49 PM   #6
j.boy
Drives: GT86
steve, sorry im kinda new to definition... the link you gave me only showed a page with text showing address of the tables. What am I supposed to do bout it? or is there a software to use these address ?
Old 01-29-2016, 01:36 AM   #7
steve99
ok open the link above
in your browser click "save page as"
I should then dowload and save a a file called RR_ZA1JA01J.xml
that file is your definition file copy it from the download directory to where you store your romraider definitions
point romraider to that definition file
j.boy (02-01-2016)
Old 01-29-2016, 08:03 AM   #8
j.boy
Drives: GT86
thanks steve.. ive done it but still no load limits per RPM.. only maximum load limit which is set to 4g.
Old 01-29-2016, 05:24 PM   #9
steve99
ok, you will have to ask @Td-d if he can define those tables in that ron
Old 01-29-2016, 10:25 PM   #10
aagun
Drives: 86
what i know about what u ask are :
- Requested torque base (RPM) for A01G
- missing DTC tables for A01J
- engine load limits for A01G
- injector pulse width A01G
aagun is offline   Reply With Quote
Old 01-30-2016, 06:18 AM   #11
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I've inserted the load tables, and the tables referenced above into the definitions on Github. aagun - which injector pulse width tables - the ECT comps? Those are in there.
Td-d is offline   Reply With Quote
The Following 2 Users Say Thank You to Td-d For This Useful Post:
j.boy (02-01-2016), steve99 (01-30-2016)
Old 01-30-2016, 03:45 PM   #12
j.boy
Drives: GT86
hello Td-d, im from asia and with cal id ZA1JA01J, using the only available definition which is RR_ZA1JA01J. compared to A01G about 40+ missing tables like :
I noticed all these tables are missing on A01J definition/OTS map but present on A01G definition/OTS map.
Per injector pulse width compensation A to H
Engine load limits B & C maximum (RPM)
Idle speed target G
MAF correction after start (in gear) & (neutral)
Overrun fueling cut counter RPM threshold
AF 3 CL Target compensation limits
AF 3 correction limits
CL delay maximum engine speed (Per Gear)
others were DTC codes
Is there a way to add these tables on A01J ?
Old 01-30-2016, 05:34 PM   #13
Td-d
Hi j.boy - I've just checked my definitions on Github, and all those tables, except for CL delay maximum engine speed (Per Gear) and DTC codes are already defined.
Guys - please understand something - if you're using the OFT definitions, great - but it's not up to me to maintain those definitions, I don't work for OFT. I define these roms as part of the Romraider open source project for all to use - I have no issue with OFT using RR as the platform, but if they are missing tables, or have not been updated - it's up to you to check on Github for the latest versions - or to ask Shiv to update them.
I'll update the missing DTCs on Github.
The Following User Says Thank You to Td-d For This Useful Post:
j.boy (02-01-2016)
Old 01-30-2016, 05:40 PM   #14
Td-d
Actually, CL Delay Maximum Engine Speed Per Gear is also defined. So outside of the fact that the DTC list was updated (and expanded) some time after this definition was completed - it is complete.
Pool Tables? Nevermore Off-Topic Lounge [WARNING: NO POLITICS] 37 03-01-2016 01:03 PM
Misihimoto Intake Tables for Rom Raider efactor84 Software Tuning 7 08-07-2015 05:39 PM
OFT E85 Tune w/ Modifed MAF tables SpeedFromSwede Software Tuning 2 02-18-2015 09:25 AM
Coffee Tables? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 11 10-20-2014 03:51 PM
Can DBW tables be changed via Ecutek tune??? Norkoastal Engine, Exhaust, Transmission 1 09-11-2012 06:51 PM
