Old 02-27-2019, 11:57 AM   #1
dstrout
dstrout's Avatar
Slightly wider stagger in front OK?
I’m trying to fit Enkei 18x9.5 +45 with 265/35-18 GT Radial SX2’s on my ‘13 BRZ. Rears fit fine with no spacer at 26” ride height. No rub on suspension or fenders.
The fronts barely rub the coils. Can I get away with a 3 or 5 mm spacer on the front but not running the same in the rear? I’d like to avoid pushing the rears any closer to the fenders if I don’t have to. The car is strictly track day, if it matters.
Thanks!
dstrout is offline   Reply With Quote
Old 02-27-2019, 02:20 PM   #2
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
All good. Send it.
MCTeeJ is offline   Reply With Quote
Old 02-27-2019, 06:05 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks!
Yes, the track width is different from the factory front and rear anyway. I mean, you have already upsized your tires waaay more than 3mm to 5mm width. So, the spacer won't make any difference.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
dstrout (02-27-2019), Ultramaroon (02-27-2019)
Alignment: Car wanders slightly with zero toe up front. swarb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-12-2015 04:52 AM
FS: slightly used OEM FRS front BUMPER w/ Lip JonMotoring Exterior Parts (Aero, Lighting, Etc.) 31 08-07-2014 03:21 PM
Hp vs stagger Howardwei Tracking / Autocross / HPDE / Drifting 1 04-06-2014 02:39 PM
17" stagger? [8.5 / 9.5]? ZionsWrath Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-16-2014 06:42 PM
Staggered or non-stagger ?! AJ PwR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-29-2012 05:36 PM
