Old 02-27-2019, 11:39 AM   #1
FRS_KOTO
Drives: Raven
low coolant level
Dealer burp the radiator after 50 miles, coolant level is low again and no sign of leakage. Internal leak ?
FRS_KOTO is offline   Reply With Quote
Old 02-27-2019, 11:44 AM   #2
What do you mean by "low"? Low in the reservoir? Low in the rad? How low is "low"? Have you checked with the engine both hot and cold?
Old 02-27-2019, 12:08 PM   #3
FRS_KOTO
Drives: Raven
low on reservoir when cold . Dealer top it off when it was hot.
Old 02-27-2019, 01:53 PM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Per the manual, you're supposed to top off the overflow reservoir when it's cold.
EndlessAzure is offline   Reply With Quote
Old 02-27-2019, 02:06 PM   #5
It is supposed to be low in the reservoir when cold. It works by pushing coolant into the reservoir when it get hot and expands. When the engine cools down it sucks it back into the rad. It is an expansion reservoir so that it doesn't just spill onto the ground when the engine is hot. It is not a fill to this line type situation like brake fluid or such. Even when the engine is hot it will not always fill the reservoir since there is no set amount of flow back and forth. As long as there is some in there at all then you are fine. If you fill it too much when cold then it will just push the excess out when it heats up.
Old 02-27-2019, 06:21 PM   #6
Silverz
Drives: Black frs
I’ve noticed there is about a two inch difference in the reservoir between hot and cold engine.
I’m about 1 inch below the full line when engine is cool and 1 inch above the full line engine is hot.
I think if you are between the low and full line when the engine is cold in the reservoir, you should be fine.
Silverz is offline   Reply With Quote
Old 02-27-2019, 06:45 PM   #7
Grady
Grady's Avatar
Leave the cap on. Service the resivior. There can be air trapped in the system with multiple heat and cool cycles it will work its way out.
Old 02-27-2019, 07:45 PM   #8
humfrz
DANG, FRS_KOTO - are you new to cars?
Maybe you are just really old with cars? In that case, back in the old days, radiators didn't have separate overflow reservoirs, the expansion of the coolant was dealt with in the top of the radiator.
Now, if you are new to cars (and that's OK, we all were new at one time - it took me a while to learn the pedal dance in our model T - ), I suggest you read the manual carefully and if you have any questions (after doing a search) post up your question here on the forum and someone will help you out.
humfrz
Old 02-27-2019, 09:33 PM   #9
FRS_KOTO
Drives: Raven
Dealer says, they had to call a subie tech since the valve spring replacement procedure doesnt include the re burp radiator process. “ special procedure “ due to an angled radiator on these vehicles. Anyway, dealer added coolant for the second time and will check back tomorrow if coolant level slurp it again . Thanks everyone for jumping in and appreciate your kindness and feel younger with greyed hair .
Old 02-27-2019, 09:40 PM   #10
FRS_KOTO
Drives: Raven
it was below the “ low” line after driving 50 miles .
Old 02-28-2019, 09:38 PM   #11
Silverz
Drives: Black frs
When I changed my radiator fluid and had to follow the procedure outlined in diy section which involved running the heater, releasing the air, refilling the radiator and reservoir a few times.
Old 02-28-2019, 10:02 PM   #12
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Here is the simple fix for under $1
Go to any supermarket
Buy distilled water
Open hood
Pour in a cup or two to the coolant reservoir
Problem solved.
If you want to be a high roller
Go to any Toyota/Subaru dealership and/or online -$40ish
Buy coolant
Open hood
Problem solved.
All cars no matter how modern will use up a small amount of coolant. Due to simple evaporation. Since it's mostly water. Water near hot objects such as engines or anything that gives off heat will have an evaporating effect.
Old 02-28-2019, 10:14 PM   #13
ermax
ermax's Avatar
If you keep adding water you end up deluding it to much and next thing you know your pump is gone. Doubt you would use this much but it’s best to just go the high roller route.
Old 03-01-2019, 01:59 AM   #14
humfrz
Well, I reckon that would depend on how much you have to add. It's my understanding (after looking at the boiling points of the major ingredients of the coolant), that the water portion would boil off (evaporate) first.
Therefore, if the loss is due to evaporation, it would be OK to top it off with distilled or demineralized water. However, if the loss is due to leaking, it might be best to top off with the store bought blue stuff.
humfrz
Low Coolant level @ 20k? Help.. Jfheisenberg Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 10-29-2021 12:01 PM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 08:37 PM
Low coolant level? brzzy Engine, Exhaust, Transmission 7 04-11-2016 02:16 PM
Should I be concerned with coolant and oil level? B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-28-2014 12:03 AM
Coolant level when cold GloriousJ Scion FR-S / Toyota 86 GT86 General Forum 3 05-29-2013 08:03 PM
