Old 04-11-2016, 01:13 PM   #1
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Low coolant level?
I just recently had my car in for regular scheduled service & maintenance about a month ago.
Today while I was getting my car detailed, I looked into my engine bay and noticed that my coolant level was near "Low".
Is this normal/acceptable? Should it always be at full? Why wasn't this topped up at my service appointment - I mean, I paid for it.
I have some time today to go to my local dealer but wanted to get some advice form the public first.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 04-11-2016, 01:18 PM   #2
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
How recently had you turned off the car? I assume you drove it to the detail location.
VIP BRZ is offline   Reply With Quote
Old 04-11-2016, 01:24 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Its fine I will fill mine up and it always goes back down to around that level and stays there when cold.
Old 04-11-2016, 01:26 PM   #4
brzzy
@anthonysestito
brzzy's Avatar
Car was literally just turned off. But yeah, drove to detail shop
IG: @ANTHONYSESTITO
Old 04-11-2016, 01:28 PM   #5
VIP BRZ
VIP BRZ's Avatar
Yea i was going to say, mine seems to stay pretty low no matter what.
That plus the warm engine, looks totally normal to me.
The Following 2 Users Say Thank You to VIP BRZ For This Useful Post:
brzzy (04-11-2016), go_a_way1 (04-11-2016)
Old 04-11-2016, 01:30 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Just add a bit to be on the safe side, it's nothing to be worry about unless you are in the middle of a really long trip.
The Following User Says Thank You to chaoskaze For This Useful Post:
brzzy (04-11-2016)
Old 04-11-2016, 02:01 PM   #7
Let's be very clear here. That is a coolant expansion/overflow tank and does not reflect the level of the cooling system. Yes, some will need to be added if bone dry but as long as something is in it then the coolant system is not "low".
brzzy (04-11-2016), nikitopo (03-08-2018), VIP BRZ (04-11-2016)
Old 04-11-2016, 02:16 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
As long as you are between low and high you are fine.
If you are paranoid, add some distilled water.
-alex
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Should I be concerned with coolant and oil level? B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-28-2014 12:03 AM
Coolant level when cold GloriousJ Scion FR-S / Toyota 86 GT86 General Forum 3 05-29-2013 08:03 PM
My oil level was low! FRSjeff Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 12-15-2012 11:22 PM
