Old 02-26-2019, 10:42 PM   #1
GrabTheWheel
Drives: 16' BRZ
MoTeC on an Android tablet?
Is there anyway to display info from MoTeC M130 on an Android head unit like you can with OBD II and Torque? Seems like there should be a way to do this...
GrabTheWheel is offline   Reply With Quote
Old 02-27-2019, 03:55 AM   #2
steve99
standard ecu and ecu firmware is required by law to enable basic diagnostic info logging and code reset via a standard obd interface, if theor was no laws or standards then manufacturers probably would not do it.
Motec being aftermarket and costing mega bucks is extremly unlikely to allow anything but motec systems and add on bits to talk to a motec ecu, ie they will want to sell you their bespoke system likely expensive.
GrabTheWheel (02-27-2019)
Old 03-01-2019, 12:11 PM   #3
GrabTheWheel
Drives: 16' BRZ
Well for those who are curious I found a solution from these guys gaugeart but I have to say it looks pretty GHETTO.
https://gaugeart.com/product/gaugear...gauge-adapter/
The Following User Says Thank You to GrabTheWheel For This Useful Post:
steve99 (03-01-2019)
Old 03-01-2019, 01:22 PM   #4
tomm.brz
Drives: brz 2017 hksv2
anyway if you read latest changelog of Ecu Connect android app of ecutek, it says "fixed connection to GT R motec ecm"
so it does read motec ecu
so maybe even brz gt86 ecu, but you need ecutek bluetooth obd
Old 03-04-2019, 07:41 PM   #5
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
You could use build to send out any CAN data the ecutek or oem sends.
Better yet get a color dash and be done.
Carolina Dyno is offline   Reply With Quote
200mm android head unit with android lollipop rsingh Electronics | Audio | NAV | Infotainment 3 05-23-2016 08:48 PM
Android Tablet | ELA UI Pre-Release Dezoris Electronics | Audio | NAV | Infotainment 32 10-28-2013 06:51 AM
Need android tablet recommendation SubaSteve Electronics | Audio | NAV | Infotainment 3 08-29-2013 09:59 PM
Recommend an Android tablet CA2 Electronics | Audio | NAV | Infotainment 6 03-08-2013 05:18 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
