Drives: 2015 Scion FR-S
I'm tad curious, I currently have a 2015 FRS. Prior to posting this I did my search and did not yielded any results too my inquiry, so don't bash me on if I missed something.
Some people are saying to use Subaru OEM Oil Filters, (smaller/taller once) meanwhile others are saying to use Toyota OEM Oil Filters. I recently picked up (2) Toyota OEM Filters, Part #: 90915-YZZS1 And now with tad bit more reading, I'm wondering if the Toyota OEM filter is just as good as the Subaru OEM filter, or should I get the Subaru OEM filters next time? I mean it's just an OEM filter, this isn't K&M or HKS $40+ filter. |
Subaru motor so I'd use a Subaru filter. Either way you're not going wrong.
| The Following 2 Users Say Thank You to gravitylover For This Useful Post: | FewTooManyBeers (03-06-2019), humfrz (02-25-2019) |
Drives: 2013 WRB BRZ
You're thinking too hard about oil filters. Both are fine.
| The Following 3 Users Say Thank You to BigTuna For This Useful Post: |
Drives: _
This is what I got last time around
Drives: 2022 GR86
I had asked the same question before. Check out my thread here. There definitely is a difference
https://www.ft86club.com/forums/showthread.php?t=130486 |
#6 | |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
I doubt there is much of a difference.. If OP is really paranoid then https://www.blackstone-labs.com |
Drives: 17 Asphalt 86
Id say you are splitting hairs picking between them, both OEM filters are good quality. Stay away from the orange can of death and you are fine.
I run amsoil EA15K20-EA. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | TheBRZsKnees (11-08-2021) |
If you have so much crap in your oil that one filter is better than another then you have bigger issues.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#10 |
Orange can of death? K&N? I wanted to run the HKS Purple Oil filters, but at $40-50/ea I was like (Neh...)
#11 | |
| The Following User Says Thank You to FewTooManyBeers For This Useful Post: | Tcoat (03-06-2019) |
#12 | |
#13 |
When I get them from Subaru they ask my VIN # because there are different filters for different build periods. The difference in the filters are related to valving and flow rates. I don't know if Toyota breaks it down that way.
#14 |
No. You just walk in, explain you have a FRS + Year and here is your filter. No VIN has ever been asked of me.
| The Following User Says Thank You to FewTooManyBeers For This Useful Post: | gravitylover (03-07-2019) |
| Oil Filter Question | FewTooManyBeers | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 12-06-2019 01:19 PM |
| question about K&N air filter | relaxjim | Hawaii | 1 | 06-30-2015 04:42 PM |
| Air filter question | radroach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 10-03-2014 12:44 PM |
| JDM air filter question | BlackyRose | Engine, Exhaust, Transmission | 0 | 04-21-2014 11:36 AM |
| Trd drop in filter question | bdanisi | Engine, Exhaust, Transmission | 2 | 02-12-2013 09:48 PM |
