Old 02-24-2019, 05:45 PM   #1
Grey86
Grey86's Avatar
Drives: Tornato grey 86
thoughts on cold air intake ?
Not sure if this is the right thread but i wanna know what yours thoughts are on cold air intake.
Im wanting to remove the sound generator and clean up the engine bay a bit. I know i can buy caps to cap off the sound generator, but im tossing up between replacing the intake hose, or getting a whole new air box system.
Thanks
Grey86 is offline   Reply With Quote
Old 02-24-2019, 05:50 PM   #2
tomm.brz
Drives: brz 2017 hksv2
PITA to scale the maf in tune compared to stock airbox but well, a little bit more air enters on higher rpm
The Following User Says Thank You to tomm.brz For This Useful Post:
Teseo (02-02-2023)
Old 02-24-2019, 05:54 PM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
just replace the hose
Breadman is offline   Reply With Quote
Old 02-24-2019, 06:01 PM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
There are quite a few thread on this topic.
Grimmspeed is generally considered one of the best options for power and works with the stock tune.
Trd is a factory backed part and works with the stock tune and looks like a stock piece. Cleans up the engine bay nicely.
To get the most benefit a tune is required with any direction chosen. It is generally accepted that intakes don't do much for this platform and if your only goal is a little dress up and cleaner bay you could easily do a silicone intake pipe and get the results you're after.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
humfrz (02-24-2019), why? (02-24-2019)
Old 02-24-2019, 06:29 PM   #5
86MLR
86MLR's Avatar
Modified snorkle, noise maker delete and Mishimoto intake hose and your done.
All the added noise you could want, and none of the noise you don't.
You don't really need the Mishimoto intake, it just helps clean up after the noise maker delete.
Stock air filter is fine for NA.
Opinions may vary.
Hp and Tq claims on NA can be quite funny though, all the my "dyno say" stuff is quite a read.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
Tcoat (02-25-2019)
Old 02-24-2019, 07:08 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
1) stock intake is cold air intake too, btw
2) stock air intake is of rather efficient design. From it's bottlenecks .. probably only a bit too resistive air filter .. which was improved in MY2017 kouki, but on older twins can be simpler "fixed" with aftermarket $50 dropin air filter, netting half or even 2/3rds of aftermarket full intake gains for 1/8th of price. Using stock intake doesn't prevent one from deleting soundtube too, there are simple & cheap plugs for it too
3) if you are still set on getting complete intake, imho worth getting one, which doesn't mess with MAF sensor readings to force leaning of air fuel ratio to artificially ramp up power with stock ecu tune at expense of safety, but loose "extra" gains when that MAF scaling is rescaled back. Most often i've heard mentioned as with close to stock MAF scaling TRD & Grimmspeed intakes, so probably i'd consider one of those. Though my primary choice still says with stock intake+aftermarket dropin filter.
Old 02-24-2019, 09:07 PM   #7
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Look and search the forums....
Dr. BRZ is offline   Reply With Quote
The Following User Says Thank You to Dr. BRZ For This Useful Post:
x808drifter (02-25-2019)
Old 02-24-2019, 10:39 PM   #8
Jcas
Jcas's Avatar
Drives: 2013 Limited Subaru BRZ
Don't see the point the stock intake is very efficient honestly. Plus if you tune with OFT then you have to get a custom tune and mess with tables because of the intake.
Jcas is offline   Reply With Quote
Old 02-24-2019, 10:47 PM   #9
86MLR
86MLR's Avatar
Aftermarket CAI are one of the best marketed items
that cost a bomb and do little to nothing.
I admit I modded my snorkel and use a Mishimoto intake tube though, the modified snorkel for the noise, the intake because I didn't want to use a cap.
No power difference was expected, just more induction noise
Old 02-25-2019, 01:03 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I bought my car with a CAI already on it. When I logged with OFT it was seeing -8% to -10% LTFT. It was ugly and required much logging to correct the scale.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
churchx (02-25-2019)
Old 02-25-2019, 10:32 AM   #11
Timmy_Jones
Spun
Drives: 17' Focus RS
Throw in a new panel filter and be done with it. Spend your $$ elsewhere
Timmy_Jones is offline   Reply With Quote
The Following User Says Thank You to Timmy_Jones For This Useful Post:
Tcoat (02-25-2019)
Old 02-25-2019, 10:33 AM   #12
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
Your car comes equipped with a cold air intake from the factory. Enjoy!
nastynate88 is offline   Reply With Quote
R2C cold air intake thoughts? erikfallout Engine, Exhaust, Transmission 6 04-30-2018 09:31 PM
Perrin Cold Air intake CAI (black) and AVO silicone intake tube (blue) Joesurf79 Engine, Exhaust, Bolt-Ons 13 07-29-2016 03:38 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
FRS AEM Cold Air Intake KenAEM Engine, Exhaust, Transmission 28 10-24-2012 01:48 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
