Old 02-18-2019, 09:55 PM   #1
Dtjordan
Drives: 2015 scion frs
Exclamation Fuse box question and passenger power window problem
First time post, please excuse any mistakes. I just got the car used not too long ago in perfect working order. I installed a new amp and fog lights. In my installation of the fog lights, I went to test a headlight fuse and how much current it was drawing. I accedentially pused the fuse holder if you will straight down and the fuse no longer makes contact. Does anyone know how to get to the bottom side of the fuse box? My second question is relating to the power window on the passenger side. After doing all of this, the passenger window switch does not work on the driver or passenger side. When i close the door, the window does scoot up so it appears to be a problem with the switches but not the power. Any advice is welcome and thanks in advance!
Dtjordan is offline   Reply With Quote
Old 02-19-2019, 01:12 AM   #2
humfrz
Hello Dtjordan and welcome to - The Forum -
I don't understand your problem - first off, which fuse box are you referring to - the one under the hood or the one under the dash?
As far as the power windows, if you are sure the fuse is good, they can be re-set. I suggest you refer to the manual for the procedure. (I think you just hold it down for a couple of seconds - not sure).
humfrz
Old 02-19-2019, 09:34 AM   #3
As Hum said which fuse box?
Check and make sure the window lock button on the driver door has not been pushed.
Old 02-19-2019, 11:27 AM   #4
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I did this to myself a couple months ago wrestling crutches in the car.
I was suitably contrite after a quick search though.
Old 02-19-2019, 12:53 PM   #5
I do it almost every time I clean the inside of the car. So about 3 times now I guess. Sit there baffled for about 30 seconds before I clue into what happened even though I know what it was.
Old 02-19-2019, 03:24 PM   #6
maslin
Benz Tech
Drives: 2017 BRZ Premium
I keep hitting the trunk button with my knee. The springs are stiff enough that you can't see the trunk is open. But that silly light sure stays on
maslin is offline   Reply With Quote
amplifier, broken, fuse box, not working, passenger window
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Passenger side power window circuit Fastbrew Electronics | Audio | NAV | Infotainment 3 11-22-2015 10:10 PM
Blower motor (fuse/relay/resistor) problem? fx35s Issues | Warranty | Recalls / TSB 6 01-27-2015 09:06 AM
Question on passenger's window D K Electronics | Audio | NAV | Infotainment 5 06-06-2014 04:28 PM
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 02:34 PM
