Old 02-17-2019, 08:23 PM   #1
max20s14
Drives: 14' Raven M/T - 02' is300
Just changed my spark plugs! pics of old vs new
Did it without raising the engine. Was a PITA.
Busted knuckles guaranteed. I'm right at 60k miles and the plugs don't look great to me notice the white part of the spark plug. It has some corrosion starting to creep up from the head. I'm not sure if that is normal but perhaps one you you guys can chime in
max20s14 is offline   Reply With Quote
Old 02-17-2019, 08:49 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've seen that and I would not be concerned about it. Mostly surprised that there was no never seize on the threads.
I never thought this was that hard of a job. I used a flex adaptor and a magnet to fish everything out, never had to raise anything either.
Old 02-17-2019, 11:33 PM   #3
max20s14
My flex adapter broke while trying
The hard part was seperating the extensiin from the socket. Since mine have those little detents
Used An extension a hose and a magnet. Ive read or heard somewhere your not supposed to lube these plugs
Old 02-17-2019, 11:35 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Looks like you could have gone another 30k miles.
Old 02-17-2019, 11:53 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Damn that would make it harder. I just pulled the flex out far enough I could see it connect to the short extension I was using, then shoved a flat blade in there and twisted them apart.
I never heard not to lube them. I don't put plugs in without never seize. I have fixed enough stripped threads I don't care to have to deal with it again if I can avoid it.
Old 02-18-2019, 01:09 AM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Easily. Looks practically new.
Old 02-18-2019, 09:42 AM   #7
Those look almost pristine. Back in the carburetor days before ECU fuel/air management the plugs were good if they lasted 5,000 miles. To get 60,000 out of them and have them still look that good is a technological marvel and a true statement of how far things have come.
Old 02-18-2019, 09:50 AM   #8
I was disappointed when mine were changed at 138,000 miles the mechanic didn't save them for me as requested of him. Really wanted to see what they looked like after twice the expected lifespan.
Dadhawk is online now   Reply With Quote
Old 02-18-2019, 09:54 AM   #9
I will see what mine look like when I finally get them changed. Probably be three times the recommended mileage by then.
Old 02-18-2019, 11:58 AM   #10
humfrz
Yep, back in the day, I would have put those puppies right back in.
Today, if it weren't such a PIA to get them out, I would put them back in - but, since they are out - I'd replace em.
humfrz
Old 02-18-2019, 12:04 PM   #11
humfrz
I would have run them through a blaster first though.
Old 02-18-2019, 12:44 PM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Anti-seize has always been standard on plugs going into aluminium heads for me.
Old 02-18-2019, 12:53 PM   #13
humfrz
Yep, fer sure. I recall back in the day to tend to spark plugs meant to stop in at my Uncles Chevrolet dealership, pull the plugs out, put them on the sand blaster machine, gap em and put them back in. The whole process was a 15 minute job.
Picture of a back-in-the-day dirty plug, for the young-ens that think their plugs, with a slightly discolored insulator, are "dirty". -
humfrz
Old 02-18-2019, 01:00 PM   #14
humfrz
Plug condition was vital for diagnosing issues. The ECU has done away with many of those problems though.
spark plugs Legend@wheels Engine, Exhaust, Transmission 3 12-12-2018 12:13 AM
How to gap spark plugs Strife26 Engine, Exhaust, Transmission 38 01-09-2018 01:06 AM
Spark Plugs at 65K user4815 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 12-25-2017 04:19 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
