Old 02-16-2019, 04:42 PM   #1
dragway
Drives: silver
Idler Pulley Noise
Hello all, recently my BRZ has been making a high pitched whine noise coming from the front. When you increase the RPMs the noise is more noticeable, and it doesn't matter if it's in neutral or in gear.
Took the belt off to rotate the pulleys and noticed 2 of the pulleys sounding different. Do the idler pulleys sound normal to you guys?
Video of noise:
Video of idler pulleys:
dragway is offline   Reply With Quote
The Following User Says Thank You to dragway For This Useful Post:
Bonburner (04-03-2023)
Old 02-16-2019, 04:58 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Perfect example of a failed bearing.
Notice that all the others literally make no noise. If a bearing makes any noise at all, it is already toast.
Good catch.
dragway (02-17-2019), humfrz (02-16-2019)
Old 02-16-2019, 05:21 PM   #3
humfrz
Good catch.
Yep, even Bubba agrees with Ultramaroon (on this one), that bearing is shot.
(unless you're about to sell the car to someone you don't like, then just remove the pulley, pack it full of axle grease, slap it back on there - )
humfrz & Bubba
dragway (02-17-2019), Ultramaroon (02-16-2019)
Old 02-16-2019, 05:28 PM   #4
sato
sato's Avatar
Drives: Dodge Patitas
Good catch. I'll let others chime in. BUMP!
Old 02-17-2019, 02:21 AM   #5
dragway
Drives: silver
Thank you for the reply guys, I will be ordering a replacement.
Old 02-23-2019, 01:28 PM   #6
dragway
Drives: silver
Replaced the idler pulley today and the noise is gone. Glad it was something simple to replace.
The Following 2 Users Say Thank You to dragway For This Useful Post:
Ultramaroon (02-23-2019), YamahaR86 (03-04-2025)
Idler Pulley DIY Guide? shellslinger Engine, Exhaust, Transmission 30 03-18-2021 03:23 PM
BRZ Squeal, Belt and Idler pulley question Dynames05 Engine, Exhaust, Transmission 25 07-03-2019 04:53 PM
NST Crank/ Alternator/ Water pump kit & RACESENG IDLER PULLEY KIT shaynek Engine, Exhaust, Bolt-Ons 1 04-06-2018 05:09 PM
Raceseng Light weight Crank pulley and idler Vincenttam Engine, Exhaust, Bolt-Ons 2 02-05-2017 04:07 AM
changing idler pulley from vortech, dust cover? Sniper2606 Forced Induction 0 02-01-2014 04:02 PM
