Old 02-16-2019, 02:57 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
STI tS fender garnish fix?
So i realized the garnish below will only fit the actual tS fender too because even if the current brz fender looks similar, its actually still different!! I saw a post before saying they just had to shave something off.. to make this STI garnish fit non tS fenders. any clues?
leevanf is offline   Reply With Quote
Old 02-16-2019, 04:26 AM   #2
gpvecchi
gpvecchi's Avatar
Pre restyling fender trims are different from post restyling... So there are 2015 and 2017 STi badges.
gpvecchi is offline   Reply With Quote
Old 02-16-2019, 03:30 PM   #3
spike021
spike021's Avatar
This actually isn’t the issue OP is referring to. For the kouki garnish badges, they’re made to fit the JDM garnish which has a version with a different fitment so that the badge sits flush. USDM kouki garnishes are flat. So for this badge you need to trim off as much as you can of the positioning pins and then use extra 3m to get a secure fit. But it won’t be 100% flush.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 02-17-2019, 11:59 PM   #4
leevanf
leevanf's Avatar
Hey spike! You mean if i shave these 2 pins entirely off, the adhesive that came with it should be enough to hold it in properly?
Old 02-18-2019, 02:12 AM   #5
spike021
spike021's Avatar
Shave them off, but then you'll also need extra 5lb (I believe, not sure if that's sold in the Philippines) foam 3m tape. I believe my friend and I did two layers cut to fit.
It still won't be completely flush, but it'll look and hold up fine. I've had a bunch of rainy/windy weather and driven highway speeds for about two months without problems.
Old 02-18-2019, 04:47 PM   #6
J1Avs
Drives: 2018 BRZ tS
Could you link to the tape you used? Also, how did you go about shaving them off? I just picked these up from FT86SF and need to get them installed.
Thanks!
J1Avs is offline   Reply With Quote
Old 02-18-2019, 05:36 PM   #7
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
Thanks!
A dremel tool with a cutoff wheel will suffice. Or cut them off with a pair of diagonal cutters and use a file to smooth down the nubs.
Double-sided tape: https://www.amazon.com/3M-3614-15/dp...ag=googhydr-20
Or any heavy-duty/ weather resistant double sided tape.
Helios is offline   Reply With Quote
The Following User Says Thank You to Helios For This Useful Post:
J1Avs (02-18-2019)
Old 05-26-2020, 08:58 AM   #8
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
A little late but Just realized that someone else has posted what I was looking for.
Were you able to get done? I wanted to use these for my 2019 garnish.
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
TRD Style Fender Garnish Aero Fins and Fender Blades Taco Man in HD Exterior Parts (Aero, Lighting, Etc.) 2 10-14-2018 06:25 PM
WTB: Carbon Fibre Fender Garnish, Trunk Garnish, APR Mirrors ASAP Nick15Green Canada Classifieds 0 07-11-2018 07:32 PM
frs fender garnish spitfire481 Exterior Parts (Aero, Lighting, Etc.) 21 03-08-2014 08:09 AM
WTT my 86 fender garnish for brz garnish (red) VacantSky Exterior Parts (Aero, Lighting, Etc.) 0 02-08-2014 04:04 PM
