Drives: 2014 BRZ Limited A/T
STI tS fender garnish fix?
So i realized the garnish below will only fit the actual tS fender too because even if the current brz fender looks similar, its actually still different!! I saw a post before saying they just had to shave something off.. to make this STI garnish fit non tS fenders. any clues?
![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#2 |
Pre restyling fender trims are different from post restyling... So there are 2015 and 2017 STi badges.
#3 | |
This actually isn’t the issue OP is referring to. For the kouki garnish badges, they’re made to fit the JDM garnish which has a version with a different fitment so that the badge sits flush. USDM kouki garnishes are flat. So for this badge you need to trim off as much as you can of the positioning pins and then use extra 3m to get a secure fit. But it won’t be 100% flush.
Instagram: @spike.grc
#4 | |
Hey spike! You mean if i shave these 2 pins entirely off, the adhesive that came with it should be enough to hold it in properly? ![]() Sent from my iPhone using Tapatalk |
#5 | ||
It still won't be completely flush, but it'll look and hold up fine. I've had a bunch of rainy/windy weather and driven highway speeds for about two months without problems.
#6 | |
Drives: 2018 BRZ tS
Could you link to the tape you used? Also, how did you go about shaving them off? I just picked these up from FT86SF and need to get them installed. Thanks! |
#7 | |
Drives: 2014 Red Subaru BRZ
Double-sided tape: https://www.amazon.com/3M-3614-15/dp...ag=googhydr-20 Or any heavy-duty/ weather resistant double sided tape. |
| The Following User Says Thank You to Helios For This Useful Post: | J1Avs (02-18-2019) |
#8 | |
Drives: GR86 Trueno Edition
A little late but Just realized that someone else has posted what I was looking for. Were you able to get done? I wanted to use these for my 2019 garnish. Thanks Sent from my iPhone using Tapatalk |
| TRD Style Fender Garnish Aero Fins and Fender Blades | Taco Man in HD | Exterior Parts (Aero, Lighting, Etc.) | 2 | 10-14-2018 06:25 PM |
| WTB: Carbon Fibre Fender Garnish, Trunk Garnish, APR Mirrors ASAP | Nick15Green | Canada Classifieds | 0 | 07-11-2018 07:32 PM |
| frs fender garnish | spitfire481 | Exterior Parts (Aero, Lighting, Etc.) | 21 | 03-08-2014 08:09 AM |
| WTT my 86 fender garnish for brz garnish (red) | VacantSky | Exterior Parts (Aero, Lighting, Etc.) | 0 | 02-08-2014 04:04 PM |
