Old 02-13-2019, 01:21 PM   #1
IA_FRS
Drives: 2013 Asphalt FRS
Non Factory spark plug recommendation
Posting here because it's related to the valve spring recall. The dealer agreed to replace plugs and charge zero labor, so I figured I'd take advantage. Well I got a call today and apparently factory replacement plugs are on backorder. The service rep said I can bring my own plugs in and they will install. I only have a two day window, so I will need to get them from a local parts store.
The question is - what plugs should I get. Car is a totally stock daily driver.
Thanks for any input.
IA_FRS is offline   Reply With Quote
Old 02-13-2019, 01:59 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Try going to Subaru dealership next door and order BRZ spark plugs.
They are the same, and something tell me that a brand that sells all boxer engines will have spark plugs on hand for this common boxer engine...
EndlessAzure is online now   Reply With Quote
Old 02-13-2019, 02:01 PM   #3
tobin
tobin's Avatar
Drives: '13 BRZ
subarupartsforyou.com and expedited shipping
tobin is offline   Reply With Quote
Old 02-13-2019, 02:06 PM   #4
EndlessAzure
Wheels for Brains
Also, please get them to do your Throw Out Bearing and upgrade to revised 2017 part if it hasn't been done already. It's worth having the car out on the lift for an extra day or two, even if that is backordered
Old 02-13-2019, 02:45 PM   #5
IA_FRS
And to be extra sure - Toyota part number SU003-04931 and Subaru part number 22401AA801, same thing right?
Old 02-13-2019, 02:59 PM   #6
EndlessAzure
Wheels for Brains
Yes, as long as you pulled the part from the BRZ diagram.
If you google image search them, they are also identical (Denso, a long-time reputable brand)
SPARK PLUG GUiDE! Kojiap1 Engine, Exhaust, Transmission 15 04-13-2022 01:30 PM
Spark plug failure BRZ68 Issues | Warranty | Recalls / TSB 9 06-12-2017 07:44 AM
Spark Plug Replacement Dacfrs Rocky Mountains / Great Plains 4 03-21-2017 12:16 AM
P0351 bad spark plug... Jaden Engine, Exhaust, Transmission 3 01-02-2016 10:19 AM
Spark plug question Wilsonk227 BRZ First-Gen (2012+) — General Topics 19 07-03-2013 12:57 AM
