Old 02-07-2019, 05:43 PM   #1
Bluegrass
Drives: 2016 Scion FR-S RS 2.0
Battery Contents Spewed All Over Engine Bay!
Went to check/change fluids, only to discover my battery has spewed it's guts all over my engine bay! Looks to be dry. I have no idea how long its been like this.
How totaled is my car? Time to get a 2019?
I know stock batteries can be troublesome with these cars. Has this happened to anyone else? Best way to clean this up and check for damage?
Thanks!
Bluegrass is offline   Reply With Quote
Old 02-07-2019, 06:06 PM   #2
radroach
Drives: car
You're going to need to put something on that to neutralize the acid while washing that.
Old 02-07-2019, 06:09 PM   #3
Silverz
Drives: Black frs
Never seen that before. What kind of temperatures do you get in your area?
Is that your oem battery? Mine doesn’t look like that?
Has any of it eaten into anything? If not, you might just need to good a good cleaning. Make sure to get it off all the wires and stuff.
Silverz is offline   Reply With Quote
Old 02-07-2019, 06:13 PM   #4
In 45 years of working on cars. Having owned a couple of dozen junkers. Being the guy that people would ask to look at their vehicle. I have never ever seen anything like that. Are you sure it was the battery? Why is it yellow? Does the car still start?
Doesn't look like it would do the damage you would expect from battery acid. I have blown a couple up over the years and it was just clear acid that left some really clean marks on everything except bare steel bolts that rusted almost instantly. If sure it is from the battery just mix some baking soda with some water and wipe it out. Then cover the alternator, fusebox and what is left of the battery with taped on plastic and rinse the whole bay out.
Old 02-07-2019, 06:20 PM   #5
Bluegrass
Thanks everyone for the quick responses! Will definitely try the baking soda/water combo to neutralize and clean.
Car starts fine and drives great, hence I didn't notice till I popped the hood.
I assumed it was from the battery looking at the splatter pattern. It is odd though, looks like someone shot a paintball gun off under the hood.
I'll update after trying the baking soda/water. Any other general engine bay cleaners you all would recommend?
Old 02-07-2019, 06:26 PM   #6
Silverz
Drives: Black frs
Do you charge the battery a lot. Could be from overcharging. Or just a badly sealed battery.
Definately change out the battery as soon as possible.
Old 02-07-2019, 06:33 PM   #7
highway7
Drives: FRS 2013
That's not the stock battery
Battery could have been overfilled with water
highway7 is offline   Reply With Quote
Old 02-07-2019, 10:19 PM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
That's not an OEM battery -- but a replacement battery. Take it to the Toyota Dealer who installed it for you and show it to them. Might have a faulty battery and see if they can clean your engine bay for you since they installed a faulty battery.
N1rve
Old 02-09-2019, 04:23 AM   #9
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Toyota TrueStart batteries are crap. The pattern of the material looks like the battery did it, but it's yellow and the battery still works, it's not bloated and the caps are in place. So it doesn't look like the battery did it. If you have pH paper, wet a little of that stuff and see if it's an acid.
I'm wondering if some other fluid didn't blow up over there and spray looking like it came fromt he battery area. I'm with @Tcoat
Old 02-10-2019, 12:35 AM   #10
humfrz
I suggest you place a bit of baking soda paste on a couple of places to see if it fizzes or just taste a bit of the yellow residue to see it it's acetic.
If it is battery acid, just clean it up with baking soda and water, like mentioned.
I used to use a product called Gunk, to clean my engines, back in the day when I gave a shit whether they were clean =
humfrz
Old 02-10-2019, 01:38 AM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Only time I've seen something like that was oil/water mixture from head gasket.
Old 02-10-2019, 10:43 AM   #12
OH Shit that is exactly what it looks like!
Old 02-10-2019, 10:58 AM   #13
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Have you popped the battery caps and looked inside? It certainly looks to be coming from the side of the battery but the color is throwing me. Maybe someone put the wrong juice in the battery, hence the failure and strange color.
Here's to hoping it's not a head gasket.
BirdTRD is offline   Reply With Quote
Old 02-10-2019, 11:15 AM   #14
That is just it. The battery still works and the car starts. If the battery threw that much bizarre coloured crap it would not still be working. Battery acid should be a blackish translucent sort of colour. I have seen battery acid react with different surfaces and that reaction can look odd but if that was acid it should not be identical on all the different materials. It would have varied depending up the reaction with each.
battery
ECUTek Cable, Engine Mounts, Raceseng Crank Pulley, Intake Tube, Light Battery Kit jonesy Engine, Exhaust, Bolt-Ons 1 08-25-2017 10:46 AM
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-22-2017 11:18 PM
MeisterR ZetaCRD+ Coilovers pictures and contents MeisterR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 11-10-2016 09:46 AM
How long does stock battery last without engine on? jon2 Scion FR-S / Toyota 86 GT86 General Forum 15 03-15-2015 09:58 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
