Old 02-06-2019, 08:09 PM   #1
1quickchic
Drives: 2013 Panda ft86/FRS
OFT and speed density
so , in emails with shiv, ive heard/ read this is possible but he has yet to give me any solid "do this "do that" or the custom map is here. So anyone using speed density on the oft?
1quickchic is offline   Reply With Quote
Old 02-07-2019, 02:59 AM   #2
steve99
Yes @Yobiwan does
See here http://www.ft86club.com/forums/showt...t=86521&page=3
Old 02-07-2019, 09:39 AM   #3
1quickchic
I read that thread before, what hex editor is the one that works best for our cars rom?
Old 02-07-2019, 04:00 PM   #4
steve99
Any hex editor will work.
Hoever if you want to add the speed density patch you will need more than hex editor
What is your current ecu calibrarion id ?
1quickchic (02-07-2019)
Old 02-07-2019, 04:18 PM   #5
1quickchic
Ao1d and btw thanks for always helping me out!!
Old 02-07-2019, 04:47 PM   #6
steve99
Thats an auto i believe but you can use an A01I as a substitute rom unfortunatly i dont believe anyone ported the speed density patch to the auto roms anly the flex fuel patch.
So i think your out of luch with speed density.
You only cheap option will be to use a forester\wrx maf sensor and\or a bigger maf tube to stop the current setup maxing out.
Else you going to have to go to ecutek to get speed density on an auto.
Unless you good at reverse engineering and patcging ecu program code
Old 02-07-2019, 04:59 PM   #7
1quickchic
yea I already have a wrx/forester maf, but im already maxing it out. so basically SOL the bigger maf tube, I tried and it just wont tolerate doesn't work. I have been looking at ecutek , and motec, but motec is $$$, I really wonder if the ecutek can handle all I've done is what I keep contemplating, and I don't really like the non live tuning..
Old 02-07-2019, 09:43 PM   #8
steve99
Im prety sure ecutek should be avle to handle your setup new racerom 10 has closed loop fueling speed density tuning ( hybrid or total) closed loop boost control amd more lile flex fuel intergration
https://ecutek.zendesk.com/hc/en-gb/...eatures-Manual
Oh you can kind of live tune some parameters with ecutek if you get the blutooth interface you have five custom inputs whre you can set up cusrom maps to use thes inputs to say alter intake and exgaust cam on the fly and afr amd ingnition timing on the fly or any five parameters that have a custom map output
Open source Hybrid Speed Density ztan Software Tuning 57 07-05-2023 08:33 AM
ECUtek speed density tuning tool Matt@Cosworth Software Tuning 17 10-04-2016 03:55 PM
MAF (Mass Air Flow) versus Speed Density, Discussion & Debate for ALL DeliciousTuning Software Tuning 40 04-11-2015 12:56 AM
Screencast: MAF and Speed Density jamesm Software Tuning 6 02-08-2014 03:19 PM
Speed Density Possible? mrk1 Engine, Exhaust, Transmission 3 05-01-2013 01:21 AM
